- To:
- Subject: [cgal-discuss] Fast arrangement sub-section swap
- Date: Fri, 17 Oct 2008 15:23:26 -0400
Hi Y'all,
I am porting GIS code to CGAL's arrangement_2 class, using this:
CGAL::Filtered_kernel<CGAL::Simple_cartesian<NT> >
as my kernel and
CGAL::Gps_segment_traits_2<kernel>
for my Arrangement traits.
As I go around inserting edges into my kernel, eventually I hit a precondition failure somewhere in the interior of CGAL::insert_curve.
If I am using the "unassuming" insertion routines (e.g. insert_curve and not insert_non_intersecting_curve) should there ever be a precondition failure during insert? Can I simply insert a ton of ugly, poorly placed line segments and expect the arrangement to maintian correct topology and organization?
If I cannot just insert data, what restrictions are there on the data I insert?
cheers
Ben
- [cgal-discuss] Implementing custom version of CGAL::refine_Delaunay_mesh_2() function, M. Hazegh, 10/09/2008
- [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2() function, M. Hazegh, 10/10/2008
- [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2() function, M. Hazegh, 10/11/2008
- Re: [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2(), Mariette Yvinec, 10/13/2008
- Re: [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2(), M. Hazegh, 10/16/2008
- Re: [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2(), Laurent Rineau, 10/16/2008
- [cgal-discuss] Fast arrangement sub-section swap, Ben Supnik, 10/17/2008
- Re: [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2(), M. Hazegh, 10/22/2008
- Re: [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2(), Laurent Rineau, 10/22/2008
