- To:
- Subject: Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation
- Date: Mon, 3 Nov 2008 22:32:53 +0100
On Monday 03 November 2008 22:12:26
wrote:
> Hello,
> In order to generate a mesh for a 3D binary image (for example, but the
> question is also for multiply-labelled images), I need an oracle function
> which knows when a point is outside or inside (or in what domain). How do I
> do such a check, when I only have the 3D image, sampled grid of the surface
> as input? If I decide that every square is uniform, for example, won't the
> surface converge to be staircase-shaped?
You can use a trilinear interpolation, to interpolate the image values
in-between the voxels.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] Definition of the oracle in 3D images mesh generation, avaxman, 11/03/2008
- Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation, Laurent Rineau, 11/03/2008
- Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation, avaxman, 11/04/2008
- Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation, Laurent Rineau, 11/04/2008
- [cgal-discuss] A question about 3D triangulation data structure, dmyan, 11/04/2008
