- To:
- Subject: Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation
- Date: Tue, 4 Nov 2008 08:49:17 +0200
But the values are labels, marked by numbers have no specific meaning (even if
only 0 and 1), unlike, say, an implicit function to which I seek a zero-set..
Quoting Laurent Rineau
> On Monday 03 November 2008 22:12:26
> wrote:
> > Hello,
> > In order to generate a mesh for a 3D binary image (for example, but the
> > question is also for multiply-labelled images), I need an oracle function
> > which knows when a point is outside or inside (or in what domain). How do
> I
> > do such a check, when I only have the 3D image, sampled grid of the
> surface
> > as input? If I decide that every square is uniform, for example, won't the
> > surface converge to be staircase-shaped?
> You can use a trilinear interpolation, to interpolate the image values
> in-between the voxels.
> Laurent Rineau, PhD
> Engineer at GeometryFactory
> http://www.geometryfactory.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Definition of the oracle in 3D images mesh generation, avaxman, 11/03/2008
- Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation, Laurent Rineau, 11/03/2008
- Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation, avaxman, 11/04/2008
- Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation, Laurent Rineau, 11/04/2008
- [cgal-discuss] A question about 3D triangulation data structure, dmyan, 11/04/2008
