- To:
- Subject: [cgal-discuss] Definition of the oracle in 3D images mesh generation
- Date: Mon, 3 Nov 2008 23:12:26 +0200
Hello,
In order to generate a mesh for a 3D binary image (for example, but the
question
is also for multiply-labelled images), I need an oracle function which knows
when a point is outside or inside (or in what domain). How do I do such a
check, when I only have the 3D image, sampled grid of the surface as input? If
I decide that every square is uniform, for example, won't the surface converge
to be staircase-shaped?
Amir.
- [cgal-discuss] Definition of the oracle in 3D images mesh generation, avaxman, 11/03/2008
- Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation, Laurent Rineau, 11/03/2008
- Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation, avaxman, 11/04/2008
- Re: [cgal-discuss] Definition of the oracle in 3D images mesh generation, Laurent Rineau, 11/04/2008
- [cgal-discuss] A question about 3D triangulation data structure, dmyan, 11/04/2008
