- To: cgal <>
- Subject: RE: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels
- Date: Thu, 20 Nov 2008 21:37:10 +0000
- Importance: Normal
Hi, Thank you for your reply. I could do what you describe, however once I know the vertices of the voronoi cells (that is, the center of the circle/sphere of the facet/cell), and which vertex of the triangulation they belong to, I also need to know in what order they appear. In other words, I don't know how to order an unordered set of voronoi cell vertices so that when they are connected the edges between them do not cross. I don't know of a simple and above all fast way to get an ordering like this (in 3d). That is why I used the halfedge data structure from the polyhedron: given a vertex, it allows you to access the neighbouring vertices, in order. This means extra work computing repeatedly computing centers that have alreay been computed, but it was fast enough. I need this ordering to compute the surface area: I divide the polygon into triangles, and then I compute the spherical surface area of these triangles. I am not sure it is possible to determine the correct order using just the triangulation data structure? Or perhaps you know of a way to get a correct order out of an unordered set of voronoi cell vertices? Writing this out, I'm asking myself whether a voronoi cell is always convex? Because if that's not always the case, my current method (of dividing the cell into triangles) could produce the wrong result. > Date: Thu, 20 Nov 2008 09:17:23 +0100 > From: > To: > Subject: Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels > > Why not the following. > > compute the 3D Voronoi of your points. > (you can also add the center of the sphere, it will probably make the > computation > faster and do not change the triangulation of the sphere provided that the > center is inside the convex hull) > > > for each edge from the infinite vertex > (I think there will be an iterator in next release > a work around in your case is to iterate on all edges asking if they are > finite) > > for each cell incident to that edge (there is a circulator ) (this > loop describe a Voronoi cell on the sphere) > compute the Voronoi vertex on the sphere > end for > end for > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss Alle fun stuff van Messenger nu verzameld op één coole site! Windows Live Messenger |
- [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, pgoeleven, 11/19/2008
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, Olivier Devillers, 11/20/2008
- [cgal-discuss] Deleting halfedges from a polyhedron, Jens K. Becker, 11/20/2008
- RE: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, pgoeleven, 11/20/2008
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, Andreas Fabri, 11/20/2008
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, Olivier Devillers, 11/21/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, songbai, 11/20/2008
