- To:
- Subject: Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels
- Date: Thu, 20 Nov 2008 22:43:09 +0100
wrote:
Hi,
Thank you for your reply.
[snip]
Writing this out, I'm asking myself whether a voronoi cell is always convex? Because if that's not always the case, my current method (of dividing the cell into triangles) could produce the wrong result.
It is always convex, as it is the intersection of halfspaces.
andreas
- [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, pgoeleven, 11/19/2008
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, Olivier Devillers, 11/20/2008
- [cgal-discuss] Deleting halfedges from a polyhedron, Jens K. Becker, 11/20/2008
- RE: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, pgoeleven, 11/20/2008
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, Andreas Fabri, 11/20/2008
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, Olivier Devillers, 11/21/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, songbai, 11/20/2008
