- To: cgal <>
- Subject: RE: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels
- Date: Thu, 20 Nov 2008 22:13:08 +0000
- Importance: Normal
Ok thank you! One less thing to worry about... > Date: Thu, 20 Nov 2008 22:43:09 +0100 > From: > To: > Subject: Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels > > wrote: > > Hi, > > > > Thank you for your reply. > > [snip] > > > > Writing this out, I'm asking myself whether a voronoi cell is always > > convex? Because if that's not always the case, my current method (of > > dividing the cell into triangles) could produce the wrong result. > > It is always convex, as it is the intersection of halfspaces. > > andreas > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss De nieuwe Hotmail maakt je leven nog makkelijker Wees er als eerste bij. |
- [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, pgoeleven, 11/19/2008
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, Olivier Devillers, 11/20/2008
- [cgal-discuss] Deleting halfedges from a polyhedron, Jens K. Becker, 11/20/2008
- RE: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, pgoeleven, 11/20/2008
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, Andreas Fabri, 11/20/2008
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, Olivier Devillers, 11/21/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Delaunay, convex hull, Voronoi, kernels, songbai, 11/20/2008
