- To:
- Subject: [cgal-discuss] Convex_hull_d performance
- Date: Mon, 24 Nov 2008 17:31:19 +0100 (CET)
Dear all,
I am using CGAL::Convex_hull_d to compute the convex hull of a small set of
points in some n-dimensional space. Here, small means 2*n points, where n is
the number of dimensions of the space (3 <= n <= 6). Unfortunately, compute
the
convex hull is the bottleneck of my implementation. Actually, the program
spends 87% of the time calling CGAL::Convex_hull_d.insert().
Today, my implementation takes several minutes to process simple data sets and
I want to make it run faster. My question is: There is some trick that I can
use to improve CGAL’s performance assuming a small number of input points? I
believe that the bottleneck inside CGAL is memory allocation.
- [cgal-discuss] Convex_hull_d performance, laffernandes, 11/24/2008
- Re: [cgal-discuss] Convex_hull_d performance, Bernd Gaertner, 11/24/2008
- Re: Re: [cgal-discuss] Convex_hull_d performance, laffernandes, 11/24/2008
- Re: [cgal-discuss] Convex_hull_d performance, Camille Wormser, 11/24/2008
- RE: [cgal-discuss] Convex_hull_d performance, pgoeleven, 11/24/2008
- Re: [cgal-discuss] Convex_hull_d performance, Leandro Augusto Frata Fernandes, 11/24/2008
