cgal-discuss - RE: [cgal-discuss] about using Qt4.4.3 with CGAL3.4 beta version
  • To: <>
  • Subject: RE: [cgal-discuss] about using Qt4.4.3 with CGAL3.4 beta version
  • Date: Fri, 26 Dec 2008 13:35:49 +0800
  • Importance: Normal
Excuse me, may I ask if it is that when I use the newly released CGAL3.4 beta version, I should no longer use the Qt in the way that the code I pasted in the previous does?
If it is the case, may I ask if there is any example demonstrating how to use Qt4 to display a triangulation generated by the CGAL3.4 beta version ?
Thnak you very much
To:
Date: Fri, 26 Dec 2008 12:44:05 +0800
Subject: [cgal-discuss] about using Qt4.4.3 with CGAL3.4 beta version
Excuse me, may I ask something about using Qt4.4.3 with CGAL3.4 beta version in Microsoft Visual C++ 2005?
I have used nmake to compile the Qt4
Then, I set the following in Visual  C++ 2005:
In Tools->Options->Projects and Solutions->VC++ Directories->Include files, I added
$(QTDIR)\include
In
Tools->Options->Projects and Solutions->VC++ Directories->Library files, I added
$(QTDIR)\lib
In
Tools->Options->Projects and Solutions->VC++ Directories->Source files, I added
$(QTDIR)\src
However, after that, when I tried to compile the following code from the CGAL web site, I still have error.
May I ask have I missed any steps in the configuration with the Qt?
Thank you very much
#include <CGAL/basic.h>
#include <iostre am>
int main(int, char*){
  std::cout << "Sorry, this demo needs QT..." << std::endl; return 0;}
#include <CGAL/Cartesian.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/IO/Qt_widget_Triangulation_2.h>
#include <CGAL/IO/Qt_widget.h>
#include <qapplication.h>
#include <qmainwindow.h>
typedef CGAL::Cartesian<double>             K;
typedef K::Point_2                          Point_2;
typedef CGAL::Delaunay_triangulation_2<K>   Delaunay;
Delaunay dt;
class My_window : public QMainWindow {
  Q_OBJECT
public:
  My_window(int x, int y)
    widget = new CGAL::Qt_widget(this);
    widget->resiz e(x,y);
    widget->set_window(0, x, 0, y);
    connect(widget, SIGNAL(redraw_on_back()),
       this, SLOT(redraw_win()));
    connect(widget, SIGNAL(s_mousePressEvent(QMouseEvent*)),
        this, SLOT(mousePressEvent(QMouseEvent*)));
    setCentralWidget(widget);
private slots:
  void redraw_win()
    *widget << dt;
  void mousePressEvent(QMouseEvent *e)
    dt.insert(Point_2(widget->x_real(e->x()), widget->y_real(e->y())));
    widget->redraw();
private: // private data member
  CGAL::Qt_widget* widget;
//moc_source_file : tutorial2.cpp
#include "tutorial2.moc"
int main( int argc, char **argv )
    QApplicatio n app( argc, argv );
    My_window *w = new My_window(400,400);
    app.setMainWidget( w);
    w->show();
    return app.exec();
利用 Windows Live™ Photos 輕?分享相片。 簡易上載及分享照片
