cgal-discuss - RE: [cgal-discuss] about using Qt4.4.3 with CGAL3.4 beta version
  • To: <>
  • Subject: RE: [cgal-discuss] about using Qt4.4.3 with CGAL3.4 beta version
  • Date: Fri, 26 Dec 2008 23:31:51 +0800
  • Importance: Normal
THank you very much for your reply.
I am sorry that I don't know how to translate the Chinese message into English as my English is not good enough for that.
However, one of the teaching assistant in the school that I am stuying at has helped me to configure with the cmake.
But the problem still exists.
May I ask what I should do in order to "redirect output to a text file"
(because I don't know how to deal with the cmake and it is a teaching assistant in my school who helps me to deal with the cmake before)
Thank you very much for your attention
> Date: Fri, 26 Dec 2008 12:18:43 -0200
> From:
> To:
> Subject: Re: [cgal-discuss] about using Qt4.4.3 with CGAL3.4 beta version
> Hello Kwok.
> Can you translate the error message to English?
> Starting with CGAL3.4, CMake is used for configuration, so yes, you
> should not indicate the paths to QT4 manually like that.
> Try removing those directories from the VC global settings.
> If you use cmake from the command line you will be able to redirect
> output to a text file which you can send to us to help you diagnose the
> problem.
> HTH
> Fernando Cacciola
> GeometryFactory
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
