- To:
- Subject: Re: [cgal-discuss] Error while trying to create arrangment
- Date: Sat, 24 Jan 2009 15:31:08 -0600
Hi Eric,
Yes, I am inserting conic curves and it happens when I try inserting them
into the arrangement, not when I create the curves themselves. For example,
the error happens when I tried to insert the following two curves (using
the aggregate insert_curves) routine:
Curve 1: 1 1 0 -85.892 -83.638 3591.88
Curve 2: 1 52.2892 12.098 542.364 4855.69 115594
I hope this information is enough.
Thanks,
-Muhib
On Sat, 24 Jan 2009 16:31:10 +0200, Eric Berberich
wrote:
> muhibur wrote:
>> Hi
>> When I try inserting curves into the arrangement, for some curves i get
>> the
>> following error - assertion violation, dir_res!=EQUAL. Could anybody
>> suggest as to why this error occurs and how to avoid it?
>> Thanks,
>> Muhib.
> Dear Muhib,
> first of all, it would be nice if you provide more information, e.g.,
> which curves (maybe with data of a "minimal" example), which CGAL
> version, etc...
> My guess is that you are inserting conic curves, as this error only
> occurs in exactly one file.
> Arr_geometry_traits/Conic_x_monotone_arc_2.h
> It seems that you construct a 0-dimensional "arc", which is not allowed.
> The question is, whether the construction is during the arrangement
> computation (in which case there might be a bug in the package), or
> while you are creating your own input curves. But this information is
> also missing ... so, please provide more details which helps us to help
> you.
> eriC
- [cgal-discuss] simple_triangulation_3, alexa alexandra, 01/23/2009
- [cgal-discuss] Error while trying to create arrangment, muhibur, 01/24/2009
- Re: [cgal-discuss] Error while trying to create arrangment, Eric Berberich, 01/24/2009
- Re: [cgal-discuss] Error while trying to create arrangment, muhibur, 01/24/2009
- Re: [cgal-discuss] Error while trying to create arrangment, Eric Berberich, 01/25/2009
- Re: [cgal-discuss] Error while trying to create arrangment, muhibur, 01/25/2009
- <Possible follow-up(s)>
- Fw: [cgal-discuss] simple_triangulation_3, alexa alexandra, 01/24/2009
- Re: Fw: [cgal-discuss] simple_triangulation_3, Laurent Rineau (GeometryFactory), 01/24/2009
- Message not available
- Re: Fw: [cgal-discuss] simple_triangulation_3, alexa alexandra, 01/24/2009
- Fw: [cgal-discuss] simple_triangulation_3, alexa alexandra, 01/30/2009
- Re: Fw: [cgal-discuss] simple_triangulation_3, Andreas Fabri, 01/30/2009
