- To:
- Subject: Re: Fw: [cgal-discuss] simple_triangulation_3
- Date: Fri, 30 Jan 2009 13:56:35 +0100
alexa alexandra wrote:
Hello.
I need your help again.I'm trying to compile simple_triangulation_3 example and when i'm starting debug it ask's me to specify the name or the path to the executable file to be used to debug session.
I don't know what to do. Please help me.
PS: I'm using VS2008 and CGAL 3.4 .
Thanks Alexandra
Hello,
This happened to me as well. The thing was that there was an .exe
file in the directory Triangulation_2 itself, and in the directory
Triangulation_2/Release
This can happen, when you for example choose to use nmake
from inside cmake, and later you decide to use DeveveloperStudion
without having cleaned up the directory.
andreas
- [cgal-discuss] simple_triangulation_3, alexa alexandra, 01/23/2009
- [cgal-discuss] Error while trying to create arrangment, muhibur, 01/24/2009
- Re: [cgal-discuss] Error while trying to create arrangment, Eric Berberich, 01/24/2009
- Re: [cgal-discuss] Error while trying to create arrangment, muhibur, 01/24/2009
- Re: [cgal-discuss] Error while trying to create arrangment, Eric Berberich, 01/25/2009
- Re: [cgal-discuss] Error while trying to create arrangment, muhibur, 01/25/2009
- <Possible follow-up(s)>
- Fw: [cgal-discuss] simple_triangulation_3, alexa alexandra, 01/24/2009
- Re: Fw: [cgal-discuss] simple_triangulation_3, Laurent Rineau (GeometryFactory), 01/24/2009
- Message not available
- Re: Fw: [cgal-discuss] simple_triangulation_3, alexa alexandra, 01/24/2009
- Fw: [cgal-discuss] simple_triangulation_3, alexa alexandra, 01/30/2009
- Re: Fw: [cgal-discuss] simple_triangulation_3, Andreas Fabri, 01/30/2009
