cgal-discuss - Re: [cgal-discuss] Error while trying to create arrangment
  • To:
  • Subject: Re: [cgal-discuss] Error while trying to create arrangment
  • Date: Sun, 25 Jan 2009 10:21:41 +0200
muhibur wrote:
Hi Eric,
Yes, I am inserting conic curves and it happens when I try inserting them
into the arrangement, not when I create the curves themselves. For example,
the error happens when I tried to insert the following two curves (using
the aggregate insert_curves) routine:
Curve 1: 1 1 0 -85.892 -83.638 3591.88
Curve 2: 1 52.2892 12.098 542.364 4855.69 115594
I hope this information is enough.
Thanks,
-Muhib
Is your curve-data above output with operator<<. And what is the order of coefficients. Can you send us the source of this minimal demo as well. This makes it easier to analyse the structure of your program, compare to a "reimplemention" by ourselves (which would maybe not contain the actualy problem).
eriC
