cgal-discuss - Re: [cgal-discuss] CGAL demos and Qt4
  • To:
  • Subject: Re: [cgal-discuss] CGAL demos and Qt4
  • Date: Wed, 28 Jan 2009 10:40:34 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=pP1q1LEPDQXsgdL53AQXuxnRfO2OEH1qNTkZgJlusp9y+NyZJX5nc8NsWJXNGn1Xk6CAIrQjMdoCwi62AvxGKd2R0W+X0Qo4pyfLssbkMCeo0KDi3tPLLMp4i0fmmENOF9izEZmbABZtLBl3KQbpyLijJCTgHB5YFnFaRYQLHl8=;
>What is the output of CMake? Probably you miss the QGLViewer library. There
>should be a message in the CMake output that says the Alpha_shape_3 demo has
>not been configured.
I found CMakeError.log in CMakeFiles directory. In that, there are three errors
regarding Q_WS_QWS, Q_WS_MAC and Q_WS_X11.
What is that preprocessor? In an example from installation manual, Q_WS_WIN
is for windows. How can I resolve that?
Here is the log file for Q_WS_QWS section:
File C:/Program Files/CGAL-3.4-beta1/demo/Alpha_shapes_3/CMakeFiles/CMakeTmp/CheckSymbolExists.c:
#include <QtCore/qglobal.h>
void cmakeRequireSymbol(int dummy,...){(void)dummy;}
int main()
#ifndef Q_WS_X11
  cmakeRequireSymbol(0,&Q_WS_X11);
#endif
  return 0;
Determining if the Q_WS_QWS exist failed with the following output:
Change Dir: C:/Program Files/CGAL-3.4-beta1/demo/Alpha_shapes_3/CMakeFiles/CMakeTmp
Run Build Command:C:\PROGRA~1\MICROS~1.0\Common7\IDE\VCExpress.exe CMAKE_TRY_COMPILE.sln /build Debug /project cmTryCompileExec
Microsoft (R) Visual C++ Express Edition Version 9.0.30729.1.
Copyright (C) Microsoft Corp 2007. All rights reserved.
------ Build started: Project: cmTryCompileExec, Configuration: Debug Win32 ------
Compiling...
Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
Copyright (C) Microsoft Corporation.  All rights reserved.
cl /Od /I "C:\Qt\4.4.3\include" /D "WIN32" /D "_WINDOWS" /D "_DEBUG" /D "CMAKE_INTDIR=\"Debug\"" /D "_MBCS" /FD /RTC1 /MDd /Fo"cmTryCompileExec.dir\Debug\\" /Fd"C:/Program Files/CGAL-3.4-beta1/demo/Alpha_shapes_3/CMakeFiles/CMakeTmp/Debug/cmTryCompileExec.pdb" /W3 /c /Zi /TC   /Zm1000
   ".\CheckSymbolExists.c"
CheckSymbolExists.c
.\CheckSymbolExists.c(8) : error C2065: 'Q_WS_QWS' : undeclared identifier
Build log was saved at "file://c:\Program Files\CGAL-3.4-beta1\demo\Alpha_shapes_3\CMakeFiles\CMakeTmp\cmTryCompileExec.dir\Debug\BuildLog.htm"
cmTryCompileExec - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Mahmood Naderan
To:
Sent: Wednesday, January 28, 2009 9:11:34 PM
On Wednesday 28 January 2009 18:26:56 Mahmood Naderan wrote:
> Hi,
> I did not find any information about which demo(s) uses Qt4.
You are right. That can be found out having a look at the CMakeLists.txt of
each demo.
In CGAL-3.4, the demo that use Qt4 are:
  demo/Alpha_shapes_3
  demo/Circular_kernel_2
  demo/GraphicsView
  demo/Polygon
  demo/Polyhedron
  demo/Surface_mesher
  demo/Triangulation_2
> I found that  main function of Alpha_shapes_3 uses Qt4.
> After using Cmake to create .sln project for that, the build
> process does not create any executable file.
> In the manual, there are only general information regarding Qt4
> and CGAL. I remember that in  previous versions of CGAL manual,
> there were examples about how to create, call and manipulate
> Qt objects (Qt_widget), signals and .... Are there such information
> in this version of manual?
No. We have decided that the Qt4 documentation contains better tutorials and
reference pages that what we could ship in the CGAL manual.
There exists only some pages about the CGAL classes that have been created to
interact with the Graphics View Framework of Qt4:
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/GraphicsView/Chapter_main.html
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
