- To:
- Subject: Re: [cgal-discuss] CGAL demos and Qt4
- Date: Wed, 28 Jan 2009 22:30:56 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=onm3luBpW7Q0uS+FDjjksj8Nplt4MZsTjtcwh9+7P95qIP2FT8A0u65k3Q7Gd+lTVR5iCxyrSjHi+ygRTdvn7g5ZH72F1EvvOjomMO5YWBj1i1/uGFzqg7rWFjWWm7o31R97uUsZeWNw/if6RwBKtxmIOJjCw6hOExirRcIudVQ=;
>Do you use the command line tool "cmake.exe", or the graphical UI "cmake-
>gui.exe"? As you are on Windows, perhaps you have used the shortcut "CMake".
>That runs "cmakesetup.exe", which is an old and unfriendly GUI for CMake. Use
>"cmake-gui" instead. The latter will show you the messages of cmake, whereas
>cmakesetup.exe mostly hide them.
Yes I used the the shortcut to cmakesetup.exe. I will try with cmake-gui.
Mahmood Naderan
To:
Sent: Wednesday, January 28, 2009 11:18:04 PM
On Wednesday 28 January 2009 19:40:34 Mahmood Naderan wrote:
> >What is the output of CMake? Probably you miss the QGLViewer library.
> > There should be a message in the CMake output that says the Alpha_shape_3
> > demo has not been configured.
> I found CMakeError.log in CMakeFiles directory. In that, there are three
> errors regarding Q_WS_QWS, Q_WS_MAC and Q_WS_X11.
Those three "errors" probably mean that you are on Windows.
I repeat what I have just said in my previous message: have a look at the
messages that are displayed by cmake when you run a configuration step.
As I have said in my previous message, you probably forgot to install and
compile QGLViewer, and configure it in CMake.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
To:
Laurent Rineau, PhD
- [cgal-discuss] CGAL demos and Qt4, Mahmood Naderan, 01/28/2009
- Re: [cgal-discuss] CGAL demos and Qt4, Laurent Rineau (GeometryFactory), 01/28/2009
- Re: [cgal-discuss] CGAL demos and Qt4, Mahmood Naderan, 01/28/2009
- Re: [cgal-discuss] CGAL demos and Qt4, Mahmood Naderan, 01/29/2009
