cgal-discuss - Re: [cgal-discuss] CGAL demos and Qt4
  • To:
  • Subject: Re: [cgal-discuss] CGAL demos and Qt4
  • Date: Wed, 28 Jan 2009 20:48:04 +0100
On Wednesday 28 January 2009 19:40:34 Mahmood Naderan wrote:
> >What is the output of CMake? Probably you miss the QGLViewer library.
> > There should be a message in the CMake output that says the Alpha_shape_3
> > demo has not been configured.
> I found CMakeError.log in CMakeFiles directory. In that, there are three
> errors regarding Q_WS_QWS, Q_WS_MAC and Q_WS_X11.
Those three "errors" probably mean that you are on Windows.
I repeat what I have just said in my previous message: have a look at the
messages that are displayed by cmake when you run a configuration step.
Do you use the command line tool "cmake.exe", or the graphical UI "cmake-
gui.exe"? As you are on Windows, perhaps you have used the shortcut "CMake".
That runs "cmakesetup.exe", which is an old and unfriendly GUI for CMake. Use
"cmake-gui" instead. The latter will show you the messages of cmake, whereas
cmakesetup.exe mostly hide them.
As I have said in my previous message, you probably forgot to install and
compile QGLViewer, and configure it in CMake.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
