cgal-discuss - Re: [cgal-discuss] Inconsistent results in 3D booleans on Nef
  • To:
  • Subject: Re: [cgal-discuss] Inconsistent results in 3D booleans on Nef
  • Date: Sat, 31 Jan 2009 00:58:26 +0100
  • Importance: Normal
  • Sensitivity:
Hi Bart,
you can patch Nef_3 in the following way to get
rid of the inconsistencies:
- we need to manipulate the random number generator.
Therefore you add the following include line to
binop_intersection_test.h
#include <CGAL/Random.h>
and add
CGAL::Random dummy(12345);
in the beginning of function
  void operator()(Callback& cb0,
                  Callback& cb1,
                  SNC_structure& sncp,
                  SNC_structure& snc1i)
in the same file.
- the other patch is needed in the is_twin()
functions of Halffacet, Halfedge, SHalfedge,
and SHalfloop. Change the functions as follows:
Halfedge:
bool is_twin() const
{ return twin_->source()->point() < center_vertex_->point(); }
Halffacet:
{ return (CGAL::ORIGIN + twin_->plane().orthogonal_vector()) < (CGAL::ORIGIN +  supporting_plane_.orthogonal_vector()); }
SHalfedge, SHalfloop:
{ return (CGAL::ORIGIN + twin_->circle().orthogonal_vector()) < (CGAL::ORIGIN +  circle_.orthogonal_vector()); }
That's unfortunately slower than the current solution,
but I don't know a solution that is as efficient as
the current one and avoids the inconsistencies. I plan
to rewrite some of the items at some time. Then there
will be a better solution for that. The classes are
either defined in SNC_items.h (CGAL 3.3.1 and older)
or in separate files (CGAL 3.4).
Now that already two people needed that patch, I will
put it into the next CGAL release.
Peter
----- wrote: -----
To:
Sent by:
Date: 01/30/2009 11:30AM
On Fri, Jan 30, 2009 at 10:18 AM, Max <> wrote:
> Would you please give me a pointer with which I could locate
> this part of code in K-3D easily?
Hi Max,
The code can be viewed online at
http://k3d.svn.sourceforge.net/viewvc/k3d/trunk/modules/cgal/
If you want to build K-3D, instructions can be found on
http://www.k-3d.org/wiki/Getting_Started
Regards,
Bart
