cgal-discuss - Re: [cgal-discuss] Inconsistent results in 3D booleans on Nef
  • To:
  • Subject: Re: [cgal-discuss] Inconsistent results in 3D booleans on Nef
  • Date: Fri, 30 Jan 2009 11:30:15 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type :content-transfer-encoding; b=bK1Pe1kDHFlX+ZxhTAJTrF8aqbyK0U4+LvtgpwZAiWHgGlWPdzCr+6FjDRiyEaPALF ci220/l6/ATo4/Nx6SygD+1KXCBTCIlfEqIAfZXG/A9WgXaC88sXqmBX8AyeeHJqoows q+BgMW5ITnMsFS9rT+XbqnWOP9tv5ACx/V2vc=
On Fri, Jan 30, 2009 at 10:18 AM, Max
wrote:
> Would you please give me a pointer with which I could locate
> this part of code in K-3D easily?
Hi Max,
The code can be viewed online at
http://k3d.svn.sourceforge.net/viewvc/k3d/trunk/modules/cgal/
If you want to build K-3D, instructions can be found on
http://www.k-3d.org/wiki/Getting_Started
Regards,
Bart
