- To: cgal-discuss <>
- Subject: [cgal-discuss] Inconsistent results in 3D booleans on Nef Polyhedra?
- Date: Tue, 27 Jan 2009 22:25:09 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=IQcXcWNM7ZFK3yaESJujhnDAfQ0QUh806pSjvTsLaZ9tBKSU5aOZx7N2g2KH7prOIB ib90A7MG27WVYzth2zfTFq5kZ57f19KUa5oB/IquuAsbziTpYul8hDWGe8P9NxrPvgAO iy2c1UTyTWhbnDUUcYgkpbPBSVl53/Zcq1tb0=
Hi all,
While working on the integration of CGAL 3D booleans in K-3D, I had
seen some problems where the output mesh was not always the same,
depending on what machine the test was run on. The meshes were always
visually correct, but the order of the edges would change in a
seemingly random way. Until now, I always assumed this was because of
floating point errors in the source mesh, but after having worked
around those, I think I have a test case that proves this behavior may
be caused by CGAL.
Attached is a test case that takes the difference between two slightly
deformed poly-cylinders (see screenshot). Included are the input
meshes and 3 reference output meshes, that resulted from running the
test program here. Compile using:
g++ -frounding-math boolean_consistency_test.cpp -lCGAL -lmpfr -lgmp -o test
Running ./test creates a new output.nef3 that can be diffed against
the reference files. Reference file 1 results from a run inside K-3D
on 32 bit linux, file 2 is the current test program output on 32 bit
linux and output 3 was created on a 64bit linux using the test
program.
Does anyone know what could cause the differences in the outputs? All
tests were run using a homogeneous kernel with Gmpz as number type.
Kind regards,
Bart
boolean_consistency_test.tar.gz
Description: GNU Zip compressed data
Description: PNG image
- [cgal-discuss] Inconsistent results in 3D booleans on Nef Polyhedra?, Bart Janssens, 01/27/2009
- Re: [cgal-discuss] Inconsistent results in 3D booleans on Nef Polyhedra?, Peter Hachenberger, 01/29/2009
- Re: [cgal-discuss] Inconsistent results in 3D booleans on Nef, Bart Janssens, 01/30/2009
- RE: [cgal-discuss] Inconsistent results in 3D booleans on Nef, Max, 01/30/2009
- Re: [cgal-discuss] Inconsistent results in 3D booleans on Nef, Peter Hachenberger, 01/31/2009
- Re: [cgal-discuss] Inconsistent results in 3D booleans on Nef, Aviv Hurvitz, 01/30/2009
