cgal-discuss - Re: [cgal-discuss] compile an example code on win32 to produce
  • To:
  • Subject: Re: [cgal-discuss] compile an example code on win32 to produce
  • Date: Wed, 4 Feb 2009 23:12:37 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:MIME-Version:Content-Type; b=W2DNfzDGeKCQj52UtqQXr3rXwMBhd1hPjomSLNN94CqRx/NrAie/5pPGklFBga9YIY6RruuvbKNf/TI1pSaoI8kT7nRI61D6WypRsBF8xVpzOoH/MjEiqzdOEPTy59WFVBB0GcPFV6+o5GeSg3tvq7JdvwIIAOOvGAXsyOrUt4w=;
>Anyway, let me make it easier for people to find my original question, attached is the code I am trying to compile, you can simply save it to >CGAL-3.4-beta1\examples\Surface_mesher\, and I appreciate if anyone can send me the compiled binary (with cgal 3.4beta) for windows.
hi,
I buit it in windows with CGAL-3.4 beta and visual studio 9. It needs 11 arguments.
If you want, please give me those so that I will send you the results. All settings are
set to default and Release and Debug modes compiled with no problem.
I will give you more detail when I test it with VS 2005. First of all, why don't you use
VS 2008 express?
Mahmood Naderan
To:
Sent: Wednesday, February 4, 2009 9:12:08 PM
just realized that the my original thread was hijacked by this new thread.
Anyway, let me make it easier for people to find my original question, attached is the code I am trying to compile, you can simply save it to CGAL-3.4-beta1\examples\Surface_mesher\, and I appreciate if anyone can send me the compiled binary (with cgal 3.4beta) for windows.
On Wed, Feb 4, 2009 at 12:03 PM, Qianqian Fang <> wrote:
I am using "Microsoft Visual C++ 2005 Express Edition", and things are almost fine for 3.3 (not the static linking bit), but I am trying to compile my code against 3.4 beta, which I can not even set up the makefiles.
I am still hoping that someone who had set up 3.4 on a windows machine can help me compile a binary; but if I have to set up my own copy, the following is my "cmake ." output, all default installation, seems a bunch of libraries are missing and I don't know how to do with them (I don't know where to find boost_thread; GMP and MPFR are underCGAL-3.4-beta1\auxiliary, but cmake could not find them; where can I download zlib and what should I do to let cmake know where to find?)
C:\Program Files\CGAL-3.4-beta1>cmake .
-- CGAL_MAJOR_VERSION=3
-- CGAL_MINOR_VERSION=4
-- CGAL_BUILD_VERSION=
-- CGAL_SONAME_VERSION=3
-- CGAL_SOVERSION     =3.0.0
-- CGAL_REFERENCE_CACHE_DIR=
-- Building static libraries
-- Targetting Visual Studio 8 2005
-- Target build enviroment supports auto-linking
-- Using VC80 compiler.
-- Generator uses intermediate configuration directory: $(OutDir)
-- USING CMake version: 2.6.2
-- System: Windows
-- Build type: Release
-- USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR -D_CRT_SECURE_NO_
DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_
WARNINGS /MD /O2 /Ob2 /D NDEBUG -D_SECURE_SCL=0'
-- USING LDFLAGS = ' '
-- Could NOT find GMP
-- Could NOT find MPFR
CMake Error at cmake/modules/FindBoost.cmake:613 (message):
  Unable to find the requested Boost libraries.
  Boost version: 1.37.0
  Boost include path: D:/Download/boost/boost_1_37_0
  The following Boost libraries could not be found:
          boost_thread
  No Boost libraries were found.  You may need to set Boost_LIBRARYDIR to the
  directory containing Boost libraries or BOOST_ROOT to the location of
  Boost.
Call Stack (most recent call first):
  cmake/modules/CGAL_SetupBoost.cmake:12 (find_package)
  cmake/modules/CGAL_SetupDependencies.cmake:17 (include)
  CMakeLists.txt:201 (include)
-- Boost include:     D:/Download/boost/boost_1_37_0
-- Boost libraries:
-- Boost definitions:
-- USING BOOST_VERSION = '1.37.0'
-- CMAKE_INSTALL_PREFIX=C:/Program Files/CGAL
-- CGAL_Core needs GMP, cannot be configured.
-- Could NOT find ZLIB  (missing:  ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
-- OpenGL include:
-- OpenGL libraries:   glu32;opengl32
-- NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature will n
ot be activated.
-- CGAL_Qt3 needs Qt3, cannot be configured.
-- CGAL_Qt4 needs Qt4, cannot be configured.
-- Configuring incomplete, errors occurred!
On Tue, Feb 3, 2009 at 12:44 PM, Laurent Rineau (GeometryFactory) <> wrote:
On Tuesday 03 February 2009 18:29:49 Qianqian Fang wrote:
> Indeed, I was able to compile CGAL 3.3.1 on windows. Your question is
> related to
> compilation configurations. If you open CGAL80.sln with VC2005, you can
> find 4 configurations from the "Configuration Manager", each of them maps
> to a string in the compiled library file. If your code complains about a
> missing CGAL
> lib, make sure you compile for that configuration first.
> However, for 3.4beta, I was not even able to create the sln files. Cmake
> complained
> that GMP and MPFR are missing, even they do exist in the auxilary
> directory.
If your first mail of the current thread, you forgot to tell us an interesting
information: your compiler name and version¹. You say your are using VC2005.
Have you tried both Debug and Release configurations? Have you installed the
service pack 1 of VC2005?
¹) See http://www.cgal.org/bug_report.html
Actually maybe there is a problem using CGAL libraries with a static runtime.
That setup has not been really tested on Windows, as far as I know.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
