cgal-discuss - Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?
  • To:
  • Subject: Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?
  • Date: Thu, 12 Feb 2009 13:28:12 +0100
Hi,
I played around with the "Adding handles" example which was very useful
to me, but one question could not be answered by myself:
In the mentioned example there is a custom Vertex class "My_vertex_base":
template < class Gt, class Vb =
CGAL::Triangulation_vertex_base_2<Gt> >
class My_vertex_base
: public Vb
which is used in a triangulation as following:
struct K :
CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef My_vertex_base<K> Vb;
typedef CGAL::Triangulation_data_structure_2<Vb> Tds;
typedef CGAL::Triangulation_2<K,Tds> Triangulation;
typedef Triangulation::Vertex_handle Vertex_handle;
Well, besided that the rebinding is not clear to me in its full extent I
get this to work.
In the example there are some points added and one gets back a
"Vertex_handle".
Now, is it possible to "transform" this Vertex_handle in a
"My_vertex_base" ? I see that Vertex_handle has the added methods in
My_vertex_base, but still has another type. The thing is I want to get
back "My_vertex_base" instances from the triangulation, can this be done?
Thanks in advance and for your patience :)
Tom
Tom Kazimiers schrieb:
> Daniel,
> thanks for your reply. Your link is what I am looking for :)
> I realized that I indeed need a delaunay triangulation and not its dual,
> the voronoi diagram, so the manual helps alot.
> Thanks,
> Tom
> schrieb:
>>> Ideally I would like to get back a type of mine (which should extend
>>> Vertex_handle I guess) in which I could attach some information to a
>>> vertex in
>>> the diagram. Is there a way to achive this? It would be really nice if
>>> you
>>> could point me in the right direction.
>> This section of the manual was very helpful in my case:
>> 29.11 Flexibility: Using Customized Vertices and Faces
>> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_29.11
>> See the example "Adding colors".
>> Best,
>> Daniel
>> Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
>> ------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
