- To:
- Subject: [cgal-discuss] CGAL_PDB - could not include align.h
- Date: Mon, 23 Feb 2009 14:58:05 +0100
Hi everybody,
I'm using CGAL3.4 on Ubuntu 8.10 with GCC 4.3.2. jama and tnt libraries are installed.
Including CGAL/PDB/align.h leads to an error:
-- minimal example --
#include <iostream>
#include <CGAL/PDB/align.h>
int main () {
std::cout << "Minimal Example" << std::endl;
--- minimal example end ---
does not compile with:
g++ testalign.cpp -L/home/strunk/local/lib -lCGAL -lCGAL_PDB -I/home/strunk/local/include -frounding-math
I think two Iterators are not renamed from the dsrpdb switch and also two functions are only present in CGAL/PDB/internal/align_points.out.h
I renamed the iterators, included a JAMA header, changed one assert and copied two function definitions from align_points.out.h.
The diff file is available here:
http://pastebin.com/m2723c6f8
It compiles now, but I haven't checked if it works as expected yet.
Thanks for CGAL,
Timo
- [cgal-discuss] CGAL_PDB - could not include align.h, Timo Strunk, 02/23/2009
