- To:
- Subject: Re: [cgal-discuss] Learning CGAL Absolute Beginner
- Date: Mon, 23 Feb 2009 14:58:04 +0100
- Organization: INRIA
"naresh"
wrote:
> Hi
> What material should be read for CGAL Absolute Beginner ? I really
> want learn Computational Geometry but i still donot knows lot of
> words and how it's works . I know basics
> Which books should be read for Computional Geometry Algoritham as
> beginner level ?
You should click on http://www.amazon.com/
Then type "computational geometry" in the search field,
then, choose a book among on of the first entries. They are all good,
but you may find one more suitable than another, depending on your
mind (which I cannot read ;-) ) or on whether your local CS library has
it or not.
Regards,
sam.
- [cgal-discuss] use Surface mesher to re-mesh self-intersecting surfaces, Qianqian Fang, 02/22/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting surfaces, avaxman, 02/22/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Qianqian Fang, 02/22/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Pierre Alliez, 02/23/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Mariette Yvinec, 02/23/2009
- [cgal-discuss] CoCone and Tight CoCone with CGAL, naresh, 02/23/2009
- Re: [cgal-discuss] CoCone and Tight CoCone with CGAL, Laurent Rineau (GeometryFactory), 02/23/2009
- [cgal-discuss] Learning CGAL Absolute Beginner, naresh, 02/23/2009
- Re: [cgal-discuss] Learning CGAL Absolute Beginner, Samuel Hornus, 02/23/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Laurent Saboret, 02/23/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Qianqian Fang, 02/23/2009
