- To:
- Subject: Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting
- Date: Mon, 23 Feb 2009 17:32:25 -0500
Laurent Saboret wrote:
Mariette Yvinec wrote:
The Surface mesher will be able to handle such a situation in a
a near future.
What is missing actually is the Polyhedral_surface_traits that can handle
surface defined as a triangle soup. Such a traits is going to be provided
in the next public release.
In the current release, you can find such a traits hidden in the polyhedron
demo, as Pierre said. However you will have to hack a bit the code, ti bypass the construction of the Polyhedron_3 which does not work with a self intersecting triangular surface.
Hi Qianqian Fang,
I attached to this post the AABB_polyhedral_oracle class mentioned by Mariette above, that can remesh a triangles soup. Triangles must be convertible to type CGAL::Triangle_3.
Best regards,
hi Laurent and Mariette
thank you very much for helping me on this. I modified the example from
demo/PolyhedronMainWindow_remeshing.cpp and replaced with Laurent's
AABB_tree units. Unfortunately, g++ raised a bunch of error messages
when compiling the program. I believe the key issue is to define a
Triangle_3 object and feed to AABB_tree template, and I probably did it
in wrong.
I am wondering if either of you can take a quick look at the unit I attached,
and tell me if it is what you expected, particularly the definition of classes.
I really appreciate your time and patience for helping me to solve this
problem.
Qianqian
#include "AABB_polyhedral_oracle.h" #include "AABB_tree.h" #include <fstream> #include <CGAL/Triangle_3.h> #include <CGAL/Simple_cartesian.h> #include <CGAL/Surface_mesh_default_triangulation_3.h> #include <CGAL/Complex_2_in_triangulation_3.h> #include <CGAL/make_surface_mesh.h> #include <CGAL/Surface_mesh_default_criteria_3.h> #include <CGAL/IO/Complex_2_in_triangulation_3_file_writer.h> #include <CGAL/IO/Complex_2_in_triangulation_3_polyhedron_builder.h> typedef CGAL::Simple_cartesian<double> Kernel; typedef Kernel::Triangle_3 Surface; int main(int argc, char**argv){ Surface surface; // I hope to read in a triangular surface, say in OFF format, to surface std::ifstream is(argv[1]) ; is >> surface ; // if(!surface) return; // remesh typedef CGAL::Surface_mesh_default_triangulation_3 Tr; typedef CGAL::Complex_2_in_triangulation_3<Tr> C2t3; typedef Tr::Geom_traits GT; Tr tr; // 3D-Delaunay triangulation C2t3 c2t3(tr); // 2D-complex in 3D-Delaunay triangulation // initialize the parameters double diag = 100; // better from something computed from surface bool ok; double angle = 25.; // [1~30] double sizing = diag*0.05; // [diag*1e-5,diag] double approx = diag*0.005; // [diag*1e-6,diag] // meshing parameters CGAL::Surface_mesh_default_criteria_3<Tr> facets_criteria(angle,sizing,approx); // AABB tree std::cout << "Build AABB tree..."; typedef CGAL::Simple_cartesian<double> Simple_cartesian_kernel; typedef CGAL::AABB_tree<Simple_cartesian_kernel,Surface> Tree; Tree tree; tree.build_faces(surface); // input surface typedef CGAL::AABB_polyhedral_oracle<Surface,GT,Simple_cartesian_kernel> Input_surface; Input_surface input(&tree); // initial point set std::cout << "Insert initial point set..."; unsigned int nb_initial_points = 10; Surface::Point_iterator it; typedef CGAL::Cartesian_converter<Kernel,GT> Converter; Converter convert; unsigned int i = 0; for(it = surface.points_begin(); it != surface.points_end(), i < nb_initial_points; it++, i++) tr.insert(convert(*it)); // remesh std::cout << "Remesh..."; CGAL::make_surface_mesh(c2t3, input, facets_criteria, CGAL::Manifold_with_boundary_tag()); std::cout << "done (" << tr.number_of_vertices() << " vertices)" << std::endl; if(tr.number_of_vertices() > 0) { // add remesh as new polyhedron Polyhedron *pRemesh = new Polyhedron; CGAL::Complex_2_in_triangulation_3_polyhedron_builder<C2t3, Surface> builder(c2t3); pRemesh->delegate(builder); // std::ofstream os( argc > 2 ? argv[2] : "out.off" ) ; os << *pRemesh ; } }
Remesher.tar.gz
Description: GNU Zip compressed data
- [cgal-discuss] use Surface mesher to re-mesh self-intersecting surfaces, Qianqian Fang, 02/22/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting surfaces, avaxman, 02/22/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Qianqian Fang, 02/22/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Pierre Alliez, 02/23/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Mariette Yvinec, 02/23/2009
- [cgal-discuss] CoCone and Tight CoCone with CGAL, naresh, 02/23/2009
- Re: [cgal-discuss] CoCone and Tight CoCone with CGAL, Laurent Rineau (GeometryFactory), 02/23/2009
- [cgal-discuss] Learning CGAL Absolute Beginner, naresh, 02/23/2009
- Re: [cgal-discuss] Learning CGAL Absolute Beginner, Samuel Hornus, 02/23/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Laurent Saboret, 02/23/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Qianqian Fang, 02/23/2009
