- To:
- Subject: Re: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly
- Date: Wed, 4 Mar 2009 21:12:30 +0100
- Importance: Normal
- Sensitivity:
Hi Amir,
the workaround does not work because there is some code in Nef_polyhedron_3
that is specialized for Extended_homogeneous and Extended_cartesian. I guess
that the specialized code is not executed when the workaround is used. Try whether
the workaround works as follows:
#include <CGAL/Is_extended_kernel.h>
struct Kernel : public CGAL::Extended_homogeneous<NT> {};
struct Is_extended_kernel<Kernel > {
typedef Tag_true value_type;
Where did you find the workaround? I should comment on the workaround in
the Nef documentation.
Peter
Peter
To:
Date: 02/28/2009 04:35PM
Subject: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly
Hello,
I tried to operate the example "point_set_operations" of Nef3 polyhedra. I am
using a VC8(2005) with CGAL 3.4. When I try to run the example verbatim, with
the kernel definition as:
"typedef CGAL::extended_homogeneous<CGAL::gmpz> Kernel", in debug mode, it runs
VERY slowly, up to the point where I couldn't keep on and stopped the debugging
manually. If I use the workaround offered in the documentation:
"struct Kernel : public CGAL::Extended_homogeneous<NT> {};"
the constructors of N1-6 assert that there is no proper construction during
runtime.
I add the aforementioned example file.
Thanks,
Amir.
[attachment "point_set_operations.cpp" removed by Peter Hachenberger]
- Re: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly, Peter Hachenberger, 03/04/2009
- RE: [cgal-discuss] An Example of Nef Polyhedra does n't work correctly, Amir Vaxman, 03/09/2009
- RE: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly, Peter Hachenberger, 03/10/2009
- RE: [cgal-discuss] An Example of Nef Polyhedra does n't work correctly, Amir Vaxman, 03/10/2009
- RE: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly, Peter Hachenberger, 03/11/2009
