cgal-discuss - RE:  [cgal-discuss]  An Example of Nef Polyhedra does n't work correctly
  • To: <>
  • Subject: RE:  [cgal-discuss]  An Example of Nef Polyhedra does n't work correctly
  • Date: Mon, 9 Mar 2009 12:30:47 +0200
This workaround exists in the documentation of Nef Polyhedra in the CGAL manual. Still, I get very slow result when computing the arrangement of simple full planes (a minute or two for 20 planes). I aggregate every plane individually, but I can do a divide-and-conquer. Is there a possibility to insert all planes at once? The aggregation is a waste of time for this case..
Thanks,
Amir.
Sent: Wednesday, March 04, 2009 10:13 PM
To:
Subject: Re: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly
Hi Amir,
the workaround does not work because there is some code in Nef_polyhedron_3
that is specialized for Extended_homogeneous and Extended_cartesian. I guess
that the specialized code is not executed when the workaround is used. Try whether
the workaround works as follows:
#include <CGAL/Is_extended_kernel.h>
struct Kernel : public CGAL::Extended_homogeneous<NT> {};
struct Is_extended_kernel<Kernel > {
     typedef Tag_true value_type;
Where did you find the workaround? I should comment on the workaround in
the Nef documentation.
Peter
----- wrote: -----
To:
Date: 02/28/2009 04:35PM
Subject: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly
Hello,
I tried to operate the example "point_set_operations" of Nef3 polyhedra. I am
using a VC8(2005) with CGAL 3.4. When I try to run the example verbatim, with
the kernel definition as:
"typedef CGAL::extended_homogeneous<CGAL::gmpz> Kernel", in debug mode, it runs
VERY slowly, up to the point where I couldn't keep on and stopped the debugging
manually. If I use the workaround offered in the documentation:
"struct Kernel : public CGAL::Extended_homogeneous<NT> {};"
the constructors of N1-6 assert that there is no proper construction during
runtime.
I add the aforementioned example file.
Thanks,
Amir.
[attachment "point_set_operations.cpp" removed by Peter Hachenberger]
