- To: <>
- Subject: RE: [cgal-discuss] An Example of Nef Polyhedra does n't work correctly
- Date: Tue, 10 Mar 2009 14:03:02 +0200
That’s exactly what I did (the huge box), and it works much
better. I still would love it if there was some way to join several planes at
once. Amir. From: Peter Hachenberger
[mailto:] Hi
Amir, the
extended kernels are nice conceptually, but they are indeed not very fast. I
focused my
time on improving the rest of the package as very few people really need the extended
kernels. Let's find out whether you really need them, or whether it suffices to
work with the standard kernels. The
standard kernels do not support halfspaces per se. That is, without the
extended kernel we
cannot represent polyhedra bounded by an infinitely large facet. On the other
hand, we support
intersections with halfspaces. So, if you want to construct a polyhedron by
intersecting halfspaces
and the result has no infinite facets, you probably can work without the
extended kernels. You
just have to find out, how you can start. For instance you might want to start
with a huge cube and
then intersect it with all your halfspaces. Does that help you? Peter -----"Amir Vaxman"
<> wrote: ----- To: <> This
workaround exists in the documentation of Nef Polyhedra in the CGAL manual.
Still, I get very slow result when computing the arrangement of simple full
planes (a minute or two for 20 planes). I aggregate every plane individually,
but I can do a divide-and-conquer. Is there a possibility to insert all planes
at once? The aggregation is a waste of time for this case..
Thanks,
Amir.
[mailto:]
Hi
Amir, -----
wrote: ----- To:
- Re: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly, Peter Hachenberger, 03/04/2009
- RE: [cgal-discuss] An Example of Nef Polyhedra does n't work correctly, Amir Vaxman, 03/09/2009
- RE: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly, Peter Hachenberger, 03/10/2009
- RE: [cgal-discuss] An Example of Nef Polyhedra does n't work correctly, Amir Vaxman, 03/10/2009
- RE: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly, Peter Hachenberger, 03/11/2009
