- To:
- Subject: Antwort: [cgal-discuss] install cgal 3.4 devian lenny
- Date: Thu, 5 Mar 2009 16:24:17 +0100
please forget the other info:
only this is interesting for me:
after make of a special demo or example I want to let it run with the executable:
the following message arises:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
File: /usr/include/CGAL/Interval_nt.h
Line: 154
Explanation: Wrong rounding: did you forget the -frounding-math option if you
use GCC?
05.03.2009 16:01
hi I am new at CGAL and have some problem with installation.
my step have been:
deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian lenny main contrib
non-free
deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian lenny main contrib
non-free
and donwload and install with synaptics and also some other gadgets
to which places to I have to install gmp-4.2.4.tar.gz, LEDA-6.2-free-FC8_....,
mpfr... and taucs_full.tgz
to I have to add some paths in my .profile?
in the demo I wrote: cmake .
and it writes: This demo requires CGAL, QGLViewer, OpenGL and QT4, and will not
be compiled
In my opinion I diid install all of them and my comp found QGLVIewer and CGAL
later I compiled the demos and when I want to open the executing file I get
this message:
Line: 154
use GCC?
what did I miss?
Engineering Center Steyr GmbH & Co KG
Geschaeftsfuehrende Gesellschaft: Engineering Center Steyr GmbH
Geschaeftsfuehrer der geschaeftsfuehrenden Gesellschaft: Dipl. Ing. Franz Dorfer
Sitz der geschaeftsfuehrenden Gesellschaft: 4300 St. Valentin, Oesterreich
Firmenbuchgericht: St. Poelten / FN 140816h
Sitz der Gesellschaft: 4300 St. Valentin, Steyrer Strasse 32, Oesterreich
Firmenbuchgericht: St. Poelten / FN 222001y
CONFIDENTIALITY NOTE: This message contains information which may be privileged or confidential, or exempt from disclosure under applicable law. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution, retention, archiving, or copying of this communication is strictly prohibited. If you have received this e-mail in error, please notify us immediately by return e-mail to the sender of this message.
- [cgal-discuss] install cgal 3.4 devian lenny, martin.schifko, 03/05/2009
- Antwort: [cgal-discuss] install cgal 3.4 devian lenny, Martin . Schifko, 03/05/2009
- Re: Antwort: [cgal-discuss] install cgal 3.4 devian lenny, Joachim Reichel, 03/05/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Fernando Cacciola, 03/05/2009
- Re: Re: [cgal-discuss] install cgal 3.4 devian lenny, martin.schifko, 03/06/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Joachim Reichel, 03/06/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Laurent Rineau (GeometryFactory), 03/06/2009
