- To:
- Subject: Re: [cgal-discuss] install cgal 3.4 devian lenny
- Date: Fri, 6 Mar 2009 13:37:16 +0100
On Friday 06 March 2009 11:56:58
wrote:
> Tx, I synced the clock and I do not see the error message anymore. I think
> it is working.
> NIce.
> Does this mean in future I always have to write
> cmake -DCGAL_CXX_FLAGS="-frounding-math" .
> instead of
> cmake .
Mmmm. That is strange. CGAL cmake macros should have detected that your
compiler needs it. What says the command "/usr/bin/c++ --version" on you
machine?
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- Antwort: [cgal-discuss] install cgal 3.4 devian lenny, (continued)
- Antwort: [cgal-discuss] install cgal 3.4 devian lenny, Martin . Schifko, 03/05/2009
- Re: Antwort: [cgal-discuss] install cgal 3.4 devian lenny, Joachim Reichel, 03/05/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Fernando Cacciola, 03/05/2009
- Re: Re: [cgal-discuss] install cgal 3.4 devian lenny, martin.schifko, 03/06/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Joachim Reichel, 03/06/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Laurent Rineau (GeometryFactory), 03/06/2009
- Antwort: Re: [cgal-discuss] install cgal 3.4 devian lenny, Martin . Schifko, 03/06/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Fernando Cacciola, 03/10/2009
