- To:
- Subject: Re: [cgal-discuss] Sweep Line Running slow
- Date: Sat, 7 Mar 2009 11:01:20 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=uAC23snMMN6Uu0++DYzKNRq2HhYTvoJN1ZwUy3S5R0oCMblexriCED+tjscVFQotDJ h/jwRRpyd0ab4azKq3I8l2VOP4flGiPpcfuL31ikFvjzSKxHQXJw3/d6v9js0dUyjGZ0 P/nMoWJ2vyCCGKfKoSLnQTSqDXHZLNfmSEB24=
Make sure that you run the code with the NDEBUG compilation flag and with all other compiler optimizations.
Another thing, you should run the sweep line algorithm with an EXACT kernel. Quotient<double> is not a kernel which supplies exact constructions.
2009/3/7 naresh <>
HiI tried to use sweep line algoritham but it running to slow . any i idea why ? I am try to insert 200 random segments and finding intersection points but it runs almost too slow. for 200 points it take around one minutes if i used Quotient<double> as kernel inputHow can i increase the speed of it ? any idea ? If anyone want to see code i can post it.
- [cgal-discuss] how to output a point's coordinate, zengming, 03/06/2009
- Re: [cgal-discuss] how to output a point's coordinate, Samuel Hornus, 03/06/2009
- Re: Re: [cgal-discuss] how to output a point's coordinate, zengming, 03/06/2009
- Re: Re: [cgal-discuss] how to output a point's coordinate, Pedro Machado Manhães de Castro, 03/06/2009
- Re: Re: Re: [cgal-discuss] how to output a point's coordinate, zengming, 03/06/2009
- Re: Re: Re: [cgal-discuss] how to output a point's coordinate, Pedro Machado Manhães de Castro, 03/06/2009
- [cgal-discuss] How to rotate Segment_2, naresh, 03/06/2009
- [cgal-discuss] Sweep Line Running slow, naresh, 03/07/2009
- Re: [cgal-discuss] Sweep Line Running slow, Ophir Setter, 03/07/2009
- [cgal-discuss] Point Rotation problem or Bug ?, naresh, 03/12/2009
- [cgal-discuss] How to find center of mass and principal inertial axis of 3D model?, Samay Kumar, 03/13/2009
- Re: [cgal-discuss] How to find center of mass and principal inertial axis of 3D model?, naresh, 03/13/2009
- Re: [cgal-discuss] How to find center of mass and principal inertial, Ashwin N, 03/14/2009
- Re: [cgal-discuss] How to find center of mass and principal inertial, Pierre Alliez, 03/25/2009
- Re: [cgal-discuss] Point Rotation problem or Bug ?, Ashwin N, 03/14/2009
- [cgal-discuss] Alpaha shape question, naresh, 03/18/2009
- Re: [cgal-discuss] Alpaha shape question, Andreas Fabri, 03/18/2009
- Re: [cgal-discuss] Alpaha shape question, naresh, 03/19/2009
- Re: [cgal-discuss] How to rotate Segment_2, Ashwin N, 03/09/2009
