- To:
- Subject: Re: [cgal-discuss] How to find center of mass and principal inertial
- Date: Sat, 14 Mar 2009 12:12:00 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=H0b1Hznxojgx/74jWyFLvE2gJfY+MQc++RFV8oCPxYIoSR8Nv+9NtHSWI/N0G/I9J2 Ucug8tjIQUNj5Lb4jMIDPzFdf+ByqdD3XtNAYJvUo36joLng3EqNc9ugL1M2aiO6ARYg E6rqw2meOGKvHsEwpqQ+ugXe5yJYOFDXn8C5U=
On Fri, Mar 13, 2009 at 09:03, Samay Kumar
wrote:
> So, what I want is to recover center of mass and principal inertial axis of
> such polyhedron model. Can CGAL help me with this problem?
The center of mass should be calculable using CGAL::centroid:
<http://is.gd/nif0>
~ash
- Re: Re: Re: [cgal-discuss] how to output a point's coordinate, (continued)
- Re: Re: Re: [cgal-discuss] how to output a point's coordinate, zengming, 03/06/2009
- Re: Re: Re: [cgal-discuss] how to output a point's coordinate, Pedro Machado Manhães de Castro, 03/06/2009
- [cgal-discuss] How to rotate Segment_2, naresh, 03/06/2009
- [cgal-discuss] Sweep Line Running slow, naresh, 03/07/2009
- Re: [cgal-discuss] Sweep Line Running slow, Ophir Setter, 03/07/2009
- [cgal-discuss] Point Rotation problem or Bug ?, naresh, 03/12/2009
- [cgal-discuss] How to find center of mass and principal inertial axis of 3D model?, Samay Kumar, 03/13/2009
- Re: [cgal-discuss] How to find center of mass and principal inertial axis of 3D model?, naresh, 03/13/2009
- Re: [cgal-discuss] How to find center of mass and principal inertial, Ashwin N, 03/14/2009
- Re: [cgal-discuss] How to find center of mass and principal inertial, Pierre Alliez, 03/25/2009
- Re: [cgal-discuss] Point Rotation problem or Bug ?, Ashwin N, 03/14/2009
- [cgal-discuss] Alpaha shape question, naresh, 03/18/2009
- Re: [cgal-discuss] Alpaha shape question, Andreas Fabri, 03/18/2009
- Re: [cgal-discuss] Alpaha shape question, naresh, 03/19/2009
- Re: [cgal-discuss] How to rotate Segment_2, Ashwin N, 03/09/2009
- Re: Re: [cgal-discuss] how to output a point's coordinate, zengming, 03/06/2009
