- To:
- Subject: Re: [cgal-discuss] How to find center of mass and principal inertial
- Date: Wed, 25 Mar 2009 12:52:35 +0100
- Organization: INRIA
hi Samay, check the covariance matrix and centroid computation of the PCA component. if you can decompose you polyhedron into a set of tets this will work as the inertia matrix is trivially deduced from the covariance matrix. Pierre Alliez INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95 Samay Kumar a écrit :
- Re: Re: Re: [cgal-discuss] how to output a point's coordinate, (continued)
- Re: Re: Re: [cgal-discuss] how to output a point's coordinate, zengming, 03/06/2009
- Re: Re: Re: [cgal-discuss] how to output a point's coordinate, Pedro Machado Manhães de Castro, 03/06/2009
- [cgal-discuss] How to rotate Segment_2, naresh, 03/06/2009
- [cgal-discuss] Sweep Line Running slow, naresh, 03/07/2009
- Re: [cgal-discuss] Sweep Line Running slow, Ophir Setter, 03/07/2009
- [cgal-discuss] Point Rotation problem or Bug ?, naresh, 03/12/2009
- [cgal-discuss] How to find center of mass and principal inertial axis of 3D model?, Samay Kumar, 03/13/2009
- Re: [cgal-discuss] How to find center of mass and principal inertial axis of 3D model?, naresh, 03/13/2009
- Re: [cgal-discuss] How to find center of mass and principal inertial, Ashwin N, 03/14/2009
- Re: [cgal-discuss] How to find center of mass and principal inertial, Pierre Alliez, 03/25/2009
- Re: [cgal-discuss] Point Rotation problem or Bug ?, Ashwin N, 03/14/2009
- [cgal-discuss] Alpaha shape question, naresh, 03/18/2009
- Re: [cgal-discuss] Alpaha shape question, Andreas Fabri, 03/18/2009
- Re: [cgal-discuss] Alpaha shape question, naresh, 03/19/2009
- Re: [cgal-discuss] How to rotate Segment_2, Ashwin N, 03/09/2009
- Re: Re: [cgal-discuss] how to output a point's coordinate, zengming, 03/06/2009
