- To: "cgal-discuss" <>
- Subject: AW: Re: [cgal-discuss] install cgal 3.4 devian lenny
- Date: Tue, 10 Mar 2009 21:11:40 +0100
- Importance: Normal
Tx,
Do I have to make a new installatuon or does it come with an update?
BlackBerry Enterprise wireless MailSystem
***** powered by Magna Powertrain *****
----- Originalnachricht -----
Von: Fernando Cacciola
Gesendet: 10.03.2009 16:22 ZW2
An:
Betreff: Re: [cgal-discuss] install cgal 3.4 devian lenny
Joachim Reichel wrote:
Hi,
Does this mean in future I always have to write
cmake -DCGAL_CXX_FLAGS="-frounding-math" .
instead of cmake . ?
yes, this is a bug, and for the time being you need this workaround.
And FWIW the bug has just been fixed.
Best
Fernando Cacciola
www.geometryfactory.com
Engineering Center Steyr GmbH & Co KG Geschaeftsfuehrende Gesellschaft: Engineering Center Steyr GmbH Geschaeftsfuehrer der geschaeftsfuehrenden Gesellschaft: Dipl. Ing. Franz Dorfer Sitz der geschaeftsfuehrenden Gesellschaft: 4300 St. Valentin, Oesterreich Firmenbuchgericht: St. Poelten / FN 140816h Sitz der Gesellschaft: 4300 St. Valentin, Steyrer Strasse 32, Oesterreich Firmenbuchgericht: St. Poelten / FN 222001y
CONFIDENTIALITY NOTE: This message contains information which may be
privileged or confidential, or exempt from disclosure under applicable law.
If the reader of this message is not the intended recipient, or the employee
or agent responsible for delivering the message to the intended recipient,
you are hereby notified that any dissemination, distribution, retention,
archiving, or copying of this communication is strictly prohibited. If you
have received this e-mail in error, please notify us immediately by return
e-mail to the sender of this message.
- AW: Re: [cgal-discuss] install cgal 3.4 devian lenny, Martin . Schifko, 03/10/2009
- Re: AW: Re: [cgal-discuss] install cgal 3.4 devian lenny, Joachim Reichel, 03/10/2009
- Re: AW: Re: [cgal-discuss] install cgal 3.4 devian lenny, Fernando Cacciola, 03/11/2009
- Antwort: Re: AW: Re: [cgal-discuss] install cgal 3.4 devian lenny, Martin . Schifko, 03/12/2009
- Re: Antwort: Re: AW: Re: [cgal-discuss] install cgal 3.4 devian lenny, Joachim Reichel, 03/12/2009
- Antwort: Re: Antwort: Re: AW: Re: [cgal-discuss] install cgal 3.4 devian, Martin . Schifko, 03/16/2009
- Re: Re: Antwort: Re: AW: Re: [cgal-discuss] install cgal 3.4 devian, omar rodriguez, 03/16/2009
