cgal-discuss - Re: AW: Re: [cgal-discuss] install cgal 3.4 devian lenny
  • To:
  • Subject: Re: AW: Re: [cgal-discuss] install cgal 3.4 devian lenny
  • Date: Tue, 10 Mar 2009 22:11:41 -0200
Hi,
Hi,
Do I have to make a new installatuon or does it come with an update?
the bug fix will be contained in 3.4.1 (there is no release date set
yet, but probably within a month). Yes, you have to do a new
installation then.
For now, simply use the mentioned workaround. I can't imagine why one
needs to re-configure *all* demos/examples repeatedly, so this shouldn't
be a real problem.
Alternatively, if you use a tarball instead of a debian package (which has a different tree structure) you can configure all demos and examples at once while configuring the library:
cmake -DWITH_examples=TRUE -DWITH_demos .
This correctly propagates the flags in the current 3.4
HTH
Fernando Cacciola
www.geometryfactory.com
