- To:
- Subject: Re: [cgal-discuss] CGAL-3.4 compilation error ? -- Mandriva Linux
- Date: Thu, 19 Mar 2009 22:23:12 +0100
Hi,
> I am new to CGAL, and try to install CGAL-3.4 under a Mandriva Linux.
> After a 'cmake .' whichs seems correct
> the compilation process 'make' aborts with an error 2,
> and the following message, that I cannot understand
> /opt/cgal/CGAL-3.4/include/CGAL/Algebraic_structure_traits.h:417:
> erreur: syntax error before `;' token
> Also, some header files: Root_of_2.h and Quotient.h
> seem to cause warnings.
I get the same errors if I use g++ 3.3.
Is there a particular reason why you use g++ 3.3? g++-3.4 and above work
much better. See INSTALL for instructions to select the compiler.
Regards,
Joachim
- [cgal-discuss] CGAL-3.4 compilation error ? -- Mandriva Linux GNU g++, Jean-Paul Marmorat, 03/19/2009
- Re: [cgal-discuss] CGAL-3.4 compilation error ? -- Mandriva Linux, Joachim Reichel, 03/19/2009
- Re: [cgal-discuss] CGAL-3.4 compilation error ? -- Mandriva Linux, Jean-Paul Marmorat, 03/20/2009
