cgal-discuss - Re: [cgal-discuss] CGAL-3.4 compilation error ? -- Mandriva Linux
  • To:
  • Subject: Re: [cgal-discuss] CGAL-3.4 compilation error ? -- Mandriva Linux
  • Date: Fri, 20 Mar 2009 11:27:04 +0100
My compiler was not up to date. Sorry.
After a
urpmi gcc-c++
The whole process works now correctly:
cmake .
make
make install
Thanks a lot.
Let's try examples.
Regards.
Joachim Reichel a écrit :
I get the same errors if I use g++ 3.3.
Is there a particular reason why you use g++ 3.3? g++-3.4 and above work
much better. See INSTALL for instructions to select the compiler.
