- To:
- Subject: Re: [cgal-discuss] Volume and moment of inertia of Po lyhedron
- Date: Fri, 20 Mar 2009 10:55:12 +0100
- Importance: Normal
- Sensitivity:
Hi Atul,
I adapted Mirtich's volume integration code (http://www.cs.berkeley.edu/~jfc/mirtich/massProps.html)
for the 3D Nef polyhedra, but did not put it into CGAL, because
I'm not sure about license issues. I can send you the necessary
header file on Monday; I don't have it, here. If you want to don't
want to use it commercially, there is no problem.
Peter
-----Atul Thakur <> wrote: -----
To:
Date: 03/19/2009 09:01PM
Subject: [cgal-discuss] Volume and moment of inertia of Polyhedron
Hi All,
I need to find out volume and mass moment of inertia of given
polyhedrons. I looked for cgal methods doing that but could not find
any directly.
If there is no such method existing I can write mine. Just want to
check if there is some method hiding somewhere.
Another thing is area moment of inertia of 2D polygons that I need to
find. For that also I couldn't find any method.
thanks,
-Atul
- [cgal-discuss] Volume and moment of inertia of Polyhedron, Atul Thakur, 03/19/2009
- Re: [cgal-discuss] Volume and moment of inertia of Po lyhedron, Peter Hachenberger, 03/20/2009
- Re: [cgal-discuss] Volume and moment of inertia of Polyhedron, Pierre Alliez, 03/25/2009
