cgal-discuss - Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • To: <>
  • Subject: Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • Date: Sat, 21 Mar 2009 18:37:26 +0530
Hi
I think you should try like this
typedef Trianluation_2::Facet Facet;   // something here that you had used in ur programme may different i had showed only example
vector<Facet> f;
Dt.incident_facets(start, back_inserter(f));
----- Original Message -----
To:
Sent: Saturday, March 21, 2009 5:45 PM
Subject: [cgal-discuss] incident_facets function of a Delaunay triangulation
Hi, I have tried to use the function below
template <class OutputIterator>
OutputIterator t.incident_facets ( Vertex_handle v, OutputIterator facets)
Copies all Facets incident to v to the output iterator facets. Returns the resulting output iterator.
Precondition:  t.dimension() >1, v Vertex_handle(), t.is_vertex(v)..
When I tried to used it in the following way but it didn't work,
vector<Finite_facets_iterator> f;
May I ask in what other way should I use the Output iterator then ?
Thank you
Yahoo!香港提供網上安全攻略,教你如何防範黑客!了解更多
