cgal-discuss - Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • Date: Mon, 23 Mar 2009 10:44:39 +0100
Hello,
What programming language do you use? I ask because
int main(array<System::String ^> ^args)
and
System.NullReferenceException
don't look like C++
andreas
naresh wrote:
Hi
Can you change kernel for Vertex_base_for_ssr class as Exact_predicates_inexact_constructions_kernel ?
I donot anything wrong in code it should work try to match similar kernel .
----- Original Message -----
<mailto:>
*To:*
<mailto:>
*Sent:* Monday, March 23, 2009 10:13 AM
*Subject:* Re: [cgal-discuss] incident_facets function of a Delaunay
triangulation
Hi, Sorry that I have sent an empty reply before because I have hot
the wrong button.
The line that I got the exception is the line
Dt.incident_facets(start, back_inserter(f));
and after I have chnaged the vector to a list, the exception still
occur..
Thanks
--- *2009年3月23日 星期一,Query Cgal
<mailto:>>/*
寫道﹕
寄件人: Query Cgal
<mailto:>>
主題: Re: [cgal-discuss] incident_facets function of a Delaunay
triangulation
收件人:
日期: 2009 3 23 星期一 上午 4:41
--- *2009年3月23日 星期一,naresh
/<alexdowson@hotmail..com>/*
寫道﹕
寄件人: naresh
收件人:
日期: 2009 3 23 星期一 上午 4:33
Hi
in Which line you are getting System.NullReferenceException
of code ?
Hmmm... You can try this instead of this
vector<Delaunay_triangulation::Facet> f; with
list<Delaunay_triangulation::Facet> f;
try list instead of vector.
*To:*
*Sent:* Monday, March 23, 2009 9:47 AM
Hi.
Thank you for your reply.
Finally, I have tried with the following code to use the
incident_facets function.
Delaunay_triangulation Dt;
Dt.insert(Point(0,0,0));
Dt.insert(Point(10,0,0));
Dt.insert(Point(5,10,0));
Dt.insert(Point(8,8,0));
Dt..insert(Point(-3, -20, 0));
Dt.insert(Point(-5,10,0));
Finite_vertices_iterator start =
Dt.finite_vertices_begin();
However, when it has "System.NullReferenceException'
May I ask is it due to the nature of the points that I
have inserted into the triangulation?
I am using CGAL-3.3.1 and Visual C++ 2005
And I am using the triangulation with the following
declaration.
Thank you very much for your help.
typedef CGAL::Cartesian<double> Rep_class;
typedef CGAL::Vector_3<Rep_class> Vector;
typedef CGAL::Point_3<Rep_class> Point_3;
typedef CGAL::Object CGAL_object;
template < class GT, class Vb =
CGAL::Triangulation_vertex_base_3<GT> >
class Vertex_base_for_ssr
: public Vb
public:
typedef typename Vb::Vertex_handle Vertex_handle;
typedef typename Vb::Cell_handle Cell_handle;
typedef typename Vb::Point Point;
template < class TDS2 >
struct Rebind_TDS {
typedef typename Vb::template
Rebind_TDS<TDS2>::Other Vb2;
typedef Vertex_base_for_ssr<GT,
Vb2> Other;
Vector surface_normal;
vector<Vertex_base_for_ssr<GT, Vb> *>
neighbor_vertex_handle;
double fifth_nearest_dist;
int surface_label;
bool is_safe;
Vertex_base_for_ssr() : Vb()
surface_label = -1;
is_safe = false;
Vertex_base_for_ssr(const Point& p)
: Vb(p)
coordinate[0] = p.x();
coordinate[1] = p.y();
coordinate[2] = p.z();
surface_label = -1;
is_safe = false;
Vertex_base_for_ssr(const Point& p, Cell_handle c)
: Vb(p, c)
surface_label = -1;
is_safe = false;
void set_surface_normal(double x_i, double y_i, double
z_i)
surface_normal = Vector(x_i, y_i, z_i);
Vector get_surface_normal()
return surface_normal;
Point get_point()
return Vb::point();
double coordinate[3];
void set_coordiante()
coordinate[0] = point().x();
coordinate[1] = point().y();
coordinate[2] = point().z();
typedef
CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef
CGAL::Triangulation_data_structure_3<Vertex_base_for_ssr<K>
> Tds;
typedef CGAL::Delaunay_triangulation_3<K, Tds>
Delaunay_triangulation;
--- 2009年3月21日 星期六,naresh
寫道﹕
寄件人: naresh
收件人:
日期: 2009 3 21 星期六 下午 1:47
Hi
>>In fact, I am dealing with a 3D triangulation
(sorry that I forgot to mention that it is 3D in the
>>previous post.)
>>and therefore, I cannot use Facet since Facet is
not represented in 3D triangulation.
>>So, what should I do to use incident_facets() of a
3D triangulation.
I donot know which triangulation are you using. for
simple triangulation here there you can define Facet
easily . here is code..
try to modifiy with ur code
typedef
typedef CGAL::Triangulation_3<K> Triangulation;
typedef Triangulation::Facet Facet;
If there is still confusion post some code . But i
will not able reply today because saturday now and i am
off. :) I can reply on monday.
Hope this helps
Alex
To:
Sent: Saturday, March 21, 2009 6:46 PM
THank you for your reply.
previous post.)
a 3D triangulation.
Thank you
寫道﹕
寄件人: naresh
收件人:
日期: 2009 3 21 星期六 下午 1:07
Hi
I think you should try like this
typedef Trianluation_2::Facet Facet; //
something here that you had used in ur programme may
different i had showed only example
vector<Facet> f;
To:
Sent: Saturday, March 21, 2009 5:45 PM
Subject: [cgal-discuss] incident_facets
Hi, I have tried to use the function below
template <class OutputIterator>
OutputIterator t.incident_facets (
Vertex_handle v, OutputIterator facets)
Copies all Facets incident to v to
the output iterator facets. Returns the resulting output
iterator.
Precondition: t..dimension() >1 , v
Vertex_handle(), t.is_vertex(v)..
When I tried to used it in the following
way but it didn't work,
vector<Finite_facets_iterator> f;
May I ask in what other way should I use
the Output iterator then ?
Thank you
Yahoo!香港提供網上安全攻略,教你如何防範
黑客!了解更多
Yahoo!香港提供網上安全攻略,教你如何防範黑客!了
解更多
Yahoo!香港提供網上安全攻略,教你如何防範黑客!*了解更多*
<http://hk.promo.yahoo.com/security/>
