cgal-discuss - Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • Date: Sun, 22 Mar 2009 21:17:00 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.hk; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=uv2LrJmIytZifaVCPxrbEME56Gqjk4QcFfM3kx6/7qHOa6tHwF1SohYvV2kcfmWPT0+km0ZqZQDUx1DRLWhEDqr7iiXyFaOqpGhJSnXQ98uzX0YLBKnsIYVndJ1EFNm1whtiM5p/gkLanb03r5hTQyG54a/wPHiQCIWPylOglgQ=;
Hi.
Thank you for your reply.
Finally, I have tried with the following code to use the incident_facets function.
int main(array<System::String ^> ^args)
    Delaunay_triangulation Dt;
    Dt.insert(Point(0,0,0));
    Dt.insert(Point(10,0,0));
    Dt.insert(Point(5,10,0));
    Dt.insert(Point(8,8,0));
    Dt.insert(Point(-3, -20, 0));
    Dt.insert(Point(-5,10,0));
    Finite_vertices_iterator start = Dt.finite_vertices_begin();
    vector<Delaunay_triangulation::Facet> f;
    Dt.incident_facets(start, back_inserter(f));
However, when it has "System.NullReferenceException'
May I ask is it due to the nature of the points that I have inserted into the triangulation?
I am using CGAL-3.3.1 and Visual C++ 2005
And I am using the triangulation with the following declaration.
Thank you very much for your help.
typedef CGAL::Cartesian<double> Rep_class;
typedef CGAL::Vector_3<Rep_class> Vector;
typedef CGAL::Point_3<Rep_class> Point_3;
typedef CGAL::Object CGAL_object;
template < class GT, class Vb = CGAL::Triangulation_vertex_base_3<GT> >
class Vertex_base_for_ssr
  : public Vb
public:
  typedef typename Vb::Vertex_handle  Vertex_handle;
  typedef typename Vb::Cell_handle    Cell_handle;
  typedef typename Vb::Point          Point;
  template < class TDS2 >
  struct Rebind_TDS {
    typedef typename Vb::template Rebind_TDS<TDS2>::Other  Vb2;
    typedef Vertex_base_for_ssr<GT, Vb2>                        Other;
  Vector surface_normal;
  vector<Vertex_base_for_ssr<GT, Vb> *> neighbor_vertex_handle;
  double fifth_nearest_dist;
  int surface_label;
  bool is_safe;
  Vertex_base_for_ssr() : Vb()
      surface_label = -1;
      is_safe = false;
  Vertex_base_for_ssr(const Point& p)
    : Vb(p)
      coordinate[0] = p.x();
      coordinate[1] = p.y();
      coordinate[2] = p.z();
      surface_label = -1;
      is_safe = false;
  Vertex_base_for_ssr(const Point& p, Cell_handle c)
    : Vb(p, c)
      surface_label = -1;
      is_safe = false;
  void set_surface_normal(double x_i, double y_i, double z_i)
      surface_normal = Vector(x_i, y_i, z_i);
  Vector get_surface_normal()
     return surface_normal;
  Point get_point()
      return Vb::point();
  double coordinate[3];
  void set_coordiante()
     coordinate[0] = point().x();
     coordinate[1] = point().y();
     coordinate[2] = point().z();
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_data_structure_3<Vertex_base_for_ssr<K> > Tds;
typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay_triangulation;
--- 2009年3月21日 星期六,naresh <> 寫道﹕
    寄件人: naresh <>
    主題: Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
    收件人:
    日期: 2009 3 21 星期六 下午 1:47
    Hi
    >>In fact, I am dealing with a 3D triangulation (sorry that I forgot to mention that it is 3D in the >>previous post.)
    >>and therefore, I cannot use Facet since Facet is not represented in 3D triangulation.
    >>So, what should I do to use incident_facets() of a 3D triangulation.
    I donot know which triangulation are you using. for simple triangulation here there you can define Facet easily . here is code.
    try to modifiy with ur code
    typedef CGAL::Triangulation_3<K> Triangulation;
    typedef Triangulation::Facet Facet;
    If there is still confusion post some code . But i will not able reply today because saturday now and i am off. :)   I can reply on monday.
    Hope this helps
    Alex
        ----- Original Message -----
        To:
        Sent: Saturday, March 21, 2009 6:46 PM
        THank you for your reply.
        In fact, I am dealing with a 3D triangulation (sorry that I forgot to mention that it is 3D in the previous post.)
        Thank you
            寄件人: naresh <>
            收件人:
            日期: 2009 3 21 星期六 下午 1:07
            Hi
            I think you should try like this
            typedef Trianluation_2::Facet Facet;   // something here that you had used in ur programme may different i had showed only example
            vector<Facet> f;
                To:
                Sent: Saturday, March 21, 2009 5:45 PM
                Subject: [cgal-discuss] incident_facets function of a Delaunay triangulation
                Hi, I have tried to use the function below
                template <class OutputIterator>
                OutputIterator     t.incident_facets ( Vertex_handle v, OutputIterator facets)
                    Copies all Facets incident to v to the output iterator facets. Returns the resulting output iterator.
                Precondition:      t..dimension() >1 , v Vertex_handle(), t.is_vertex(v)..
                When I tried to used it in the following way but it didn't work,
                vector<Finite_facets_iterator> f;
                May I ask in what other way should I use the Output iterator then ?
                Thank you
                Yahoo!香港提供網上安全攻略,教你如何防範黑客!了解更多
