cgal-discuss - Re: [cgal-discuss] Boolean operations on Nef Polyhedra
  • To:
  • Subject: Re: [cgal-discuss] Boolean operations on Nef Polyhedra
  • Date: Tue, 24 Mar 2009 14:50:23 +0100
Hi Andreas,
interesting details to know, ok. Now i used the
typedef CGAL::Simple_cartesian<CGAL::Gmpq> Kernel;
as you suggested in the beginning of the thread. After six minutes and
1.6 Gig maximum working set size the program crashed again with the same
message, when constructing the Nef_polyhedron_3 from the Polyhedron_3.
So my question is: which kernel you would recommend? It should support
reading float values from an off file for constructing a Polyhedron_3.
The mesh consists of 188776 vertices and 378284 triangle facets.
Kind regards,
Christoph
SurgiTAIX AG Aachen
Pauwelsstraße 19
D-52074 Aachen
Mail:
I-Net: www.surgitaix.de
Tel: +49 241 9632146
Fax: +49 241 9632145
Vorstand:
Dr. Frank Portheine
Vorsitzender Aufsichtsrat:
Prof. Dr. Hans-Walter Staudte
Amtsgericht Aachen HRB 8474
UStIdNr. DE 215423410
