cgal-discuss - Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • Date: Tue, 24 Mar 2009 19:08:10 +0100
There are no #include statements
Query Cgal wrote:
Hi. Thanks for your reply.
I got the exception when I try the following piece of code. Thanks for your help
typedef CGAL::Cartesian<double> Rep_class;
typedef CGAL::Vector_3<Rep_class> Vector;
typedef CGAL::Point_3<Rep_class> Point_3;
template < class GT, class Vb = CGAL::Triangulation_vertex_base_3<GT> >
class Vertex_base_for_ssr
: public Vb
public:
typedef typename Vb::Vertex_handle Vertex_handle;
typedef typename Vb::Cell_handle Cell_handle;
typedef typename Vb::Point Point;
template < class TDS2 >
struct Rebind_TDS {
typedef typename Vb::template Rebind_TDS<TDS2>::Other Vb2;
typedef Vertex_base_for_ssr<GT, Vb2> Other;
Vector surface_normal;
vector<Vertex_base_for_ssr<GT, Vb> *> neighbor_vertex_handle;
double fifth_nearest_dist;
int surface_label;
bool is_safe;
Vertex_base_for_ssr() : Vb()
surface_label = -1;
is_safe = false;
Vertex_base_for_ssr(const Point& p)
: Vb(p)
coordinate[0] = p.x();
coordinate[1] = p.y();
coordinate[2] = p.z();
surface_label = -1;
is_safe = false;
Vertex_base_for_ssr(const Point& p, Cell_handle c)
: Vb(p, c)
surface_label = -1;
is_safe = false;
void set_surface_normal(double x_i, double y_i, double z_i)
surface_normal = Vector(x_i, y_i, z_i);
Vector get_surface_normal()
return surface_normal;
Point get_point()
return Vb::point();
double coordinate[3];
void set_coordiante()
coordinate[0] = point().x();
coordinate[1] = point().y();
coordinate[2] = point().z();
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_data_structure_3<Vertex_base_for_ssr<K> > Tds;
typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay_triangulation;
int main(array<System::String ^> ^args)
Delaunay_triangulation Dt;
Dt.insert(Point(0,0,0));
Dt.insert(Point(10,0,0));
Dt.insert(Point(5,10,0));
Dt.insert(Point(8,8,0));
vector<Vertex_handle> a;
Finite_vertices_iterator start = Dt.finite_vertices_begin();
Finite_vertices_iterator end = Dt.finite_vertices_end();
Finite_vertices_iterator curr;
list<Delaunay_triangulation::Facet> f;
Dt.incident_facets(start, back_inserter(f));
--- *2009年3月24日 星期二,Andreas Fabri /<>/* 寫道﹕
寄件人: Andreas Fabri
主題: Re: [cgal-discuss] incident_facets function of a Delaunay
triangulation
收件人:
日期: 2009 3 24 星期二 下午 5:47
Hi Query CGAL
Can you please write a minimalistic example program that produces
the error,
so that we can try to reproduce it
andreas
Query Cgal wrote:
> Excuse me, may I ask something about a strange problem I have
asked beofre?
> The problem is that when I use the incident_facets() function of
a 3D Delaunay Triangulation, I get
> System.NullReferenceException
> and I found out that the exception happens when it is executing
line 662 of triangulation_data_structure_3.h
> I am using Microsoft Visual C++ 2005 and CGAL-3.3.1
> May I ask what may be the possible reason for the problem then?
> Thank you very much
> --- *2009年3月23日 星期一,Query Cgal
</mc/compose?>>/*
寫道﹕
> 寄件人: Query Cgal
</mc/compose?>>
> triangulation
> 收件人:
..fr
</mc/compose?..fr>
> 日期: 2009 3 23 星期一 下午 12:35
> Thank you for your reply.
> I am using C++.
> The complier that I use is Visual Studio C++ 2005.
> And the CGAL version that I use is 3.3.1
> Thanks
> --- *2009年3月23日 星期一,Andreas Fabri
</mc/compose?>>/*
寫道﹕
> 寄件人: Andreas Fabri
</mc/compose?>>
Delaunay
> triangulation
> 收件人:
..fr
</mc/compose?..fr>
> 日期: 2009 3 23 星期一 上午 9:44
> Hello,
> What programming language do you use? I ask because
> and
> don't look like C++
> andreas
> naresh wrote:
> > Hi
> > Can you change kernel for Vertex_base_for_ssr class as
> Exact_predicates_inexact_constructions_kernel ?
> > I donot anything wrong in code it should work try to match
> similar kernel .
> > > ----- Original Message -----
> > *From:* Query Cgal
<mailto:cgalquery@yahoo..com.hk
</mc/compose?to=cgalquery@yahoo..com.hk>>
> > *To:*
</mc/compose?>
<mailto:
</mc/compose?>>
> > *Sent:* Monday, March 23, 2009 10:13 AM
> > *Subject:* Re: [cgal-discuss] incident_facets
function of
> a Delaunay
> > triangulation
> > Hi, Sorry that I have sent an empty reply before
because
> I have hot
> > the wrong button.
> > The line that I got the exception is the line
> > and after I have chnaged the vector to a list, the
> exception still
> > occur..
> > Thanks
</mc/compose?..hk>
<mailto:
</mc/compose?>>>/*
寫道﹕
> > 寄件人: Query Cgal
<cgalquery@yahoo..com.hk
<mailto:
</mc/compose?>>>
function of
> a Delaunay
> > triangulation
> > 收件人:
</mc/compose?>
> > 日期: 2009 3 23 星期一 上午 4:41
> > --- *2009年3月23日 星期一,naresh
/<alexdowson@hotmail...com
</mc/compose?to=alexdowson@hotmail...com>>/*
> > 寫道﹕
> > 寄件人: naresh
</mc/compose?>>
function
> of a
> > 收件人:
</mc/compose?>
> > 日期: 2009 3 23 星期一 上午 4:33
> > Hi
> > in Which line you are getting
> > of code ?
> > Hmmm... You can try this
instead of this
> > vector<Delaunay_triangulation::Facet> f; with
> > try list instead of vector.
> > *From:* Query Cgal
> > *To:*
</mc/compose?>
> > *Sent:* Monday, March 23, 2009 9:47 AM
incident_facets
> function
> > Hi.
> > Finally, I have tried with the
following code
> to use the
> > incident_facets function.
> > Dt...insert(Point(-3, -20, 0));
> > Dt.insert(Point(-5,10,0));
back_inserter(f));
> > However, when it has
> "System.NullReferenceException'
> > May I ask is it due to the nature of the
> points that I
> > have inserted into the triangulation?
> > I am using CGAL-3.3.1 and Visual C++ 2005
> > And I am using the triangulation with the
> following
> > declaration.
> > Thank you very much for your help.
> > typedef CGAL::Object CGAL_object;
> > : public Vb
> > public:
> > struct Rebind_TDS {
> > Vb2> Other;
> > int surface_label;
> > bool is_safe;
> > surface_label = -1;
> > is_safe = false;
> > : Vb(p)
> > surface_label = -1;
> > is_safe = false;
> Cell_handle c)
> > : Vb(p, c)
> > surface_label = -1;
> > is_safe = false;
double
> y_i, double
> > z_i)
y_i, z_i);
> > Point get_point()
> > return Vb::point();
> > coordinate[0] = point()..x();
> > typedef
> > typedef
> > > Tds;
> > typedef
> > --- 2009年3月21日 星期六,naresh
</mc/compose?>>
寫道﹕
> > 寄件人: naresh
</mc/compose?>>
incident_facets
> function of
> > 收件人:
</mc/compose?>
> > 日期: 2009 3 21 星期六 下午 1:47
> > Hi
> > >>In fact, I am
> dealing with a 3D triangulation
> > (sorry that I forgot to mention that
it is 3D
> in the
> > >>previous post.)
> > >>and therefore, I cannot use
Facet since
> Facet is
> > not represented in 3D triangulation.
> > >>So, what should I do to use
> incident_facets() of a
> > 3D triangulation.
> > I donot know which
> triangulation are you using. for
> > simple triangulation here there you can
> define Facet
> > easily .. here is code..
> > try to modifiy with ur code
> > typedef
> > typedef CGAL::Triangulation_3<K>
> Triangulation;
> > typedef Triangulation::Facet Facet;
> > If there is still confusion post some
> code . But i
> > will not able reply today because saturday
> now and i am
> > off. :) I can reply on monday..
> > > Hope this helps
> > Alex
> > From: Query Cgal
> > To:
..fr
</mc/compose?..fr>
> > Sent: Saturday, March 21, 2009
6:46 PM
> incident_facets
> > THank you for your reply.
> > In fact, I am dealing with a 3D
> triangulation
it is 3D
> in the
> > previous post.)
> > and therefore, I cannot use Facet
> since Facet is
> > a 3D triangulation.
> > Thank you
</mc/compose?>>
寫道﹕
> > 寄件人: naresh
</mc/compose?>>
> incident_facets
> > 收件人:
</mc/compose?>
> > 日期: 2009 3 21 星期六 下
午 1:07
> > Hi
> > I
> think you should try like this
> > typedef Trianluation_2::Facet Facet; //
> > something here that you had used in ur
> programme may
> > different i had showed only example
> > vector<Facet> f;
> back_inserter(f));
> > From: Query Cgal
> > To:
</mc/compose?>
> 2009 5:45 PM
> > Subject: [cgal-discuss]
> incident_facets
> > Hi, I have tried to
use the
> function below
> > template <class
OutputIterator>
> > OutputIterator t.incident_facets (
> > Vertex_handle v, OutputIterator facets)
> > Copies all Facets incident to v to
> > the output iterator facets. Returns the
> resulting output
> > iterator.
> > Precondition: t...dimension() >1 , v
> > Vertex_handle(), t.is_vertex(v)..
> > When I tried to used it in the following
> > way but it didn't work,
> > vector<Finite_facets_iterator> f;
> back_inserter(f));
> > May I ask in what
other way
> should I use
> > the Output iterator then ?
> > Thank you
> > Yahoo!香港提供網上安全
攻略,
> 教你如何防範
> > 黑客!了解更多
> > Yahoo!香港提供網上安全攻略,教
你如何
> 防範黑客!了
> > 解更多
> > Yahoo!香港提供網上安全攻略,教你如何防
範黑客!
> *了解更多*
> > <http://hk.promo.yahoo.com/security/
> <http://hk.promo..yahoo.com/security/>>
> > Yahoo!香港提供網上安全攻略,教你如何防範黑客!*
了解更多*
> <http://hk..promo.yahoo.com/security/>>
> > Yahoo!香港提供網上安全攻略,教你如何防範黑客!*了解
更多*
> > <http://hk.promo.yahoo.com/security/>
> -- You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> Yahoo!香港提供網上安全攻略,教你如何防範黑客!*了解更多*
Yahoo!香港提供網上安全攻略,教你如何防範黑客!*了解更多* <http://hk.promo.yahoo.com/security/>
