cgal-discuss - Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] incident_facets function of a Delaunay triangulation
  • Date: Tue, 24 Mar 2009 18:47:54 +0100
Hi Query CGAL
Can you please write a minimalistic example program that produces the error,
so that we can try to reproduce it
andreas
Query Cgal wrote:
Excuse me, may I ask something about a strange problem I have asked beofre?
The problem is that when I use the incident_facets() function of a 3D Delaunay Triangulation, I get
System.NullReferenceException
and I found out that the exception happens when it is executing line 662 of triangulation_data_structure_3.h
I am using Microsoft Visual C++ 2005 and CGAL-3.3.1
May I ask what may be the possible reason for the problem then?
Thank you very much
--- *2009年3月23日 星期一,Query Cgal
寫道﹕
寄件人: Query Cgal
主題: Re: [cgal-discuss] incident_facets function of a Delaunay
triangulation
收件人:
..fr
日期: 2009 3 23 星期一 下午 12:35
Thank you for your reply.
I am using C++.
The complier that I use is Visual Studio C++ 2005.
And the CGAL version that I use is 3.3.1
Thanks
--- *2009年3月23日 星期一,Andreas Fabri
寫道﹕
寄件人: Andreas Fabri
triangulation
收件人:
..fr
日期: 2009 3 23 星期一 上午 9:44
Hello,
What programming language do you use? I ask because
int main(array<System::String ^> ^args)
and
don't look like C++
andreas
naresh wrote:
> Hi
> Can you change kernel for Vertex_base_for_ssr class as
Exact_predicates_inexact_constructions_kernel ?
> I donot anything wrong in code it should work try to match
similar kernel .
> > ----- Original Message -----
> *From:* Query Cgal
<mailto:cgalquery@yahoo..com.hk>
> *To:*
<mailto:>
> *Sent:* Monday, March 23, 2009 10:13 AM
> *Subject:* Re: [cgal-discuss] incident_facets function of
a Delaunay
> triangulation
> Hi, Sorry that I have sent an empty reply before because
I have hot
> the wrong button.
> The line that I got the exception is the line
> Dt.incident_facets(start, back_inserter(f));
> and after I have chnaged the vector to a list, the
exception still
> occur..
> Thanks
<mailto:>>/*
寫道﹕
> 寄件人: Query Cgal
<cgalquery@yahoo..com.hk
<mailto:>>
a Delaunay
> triangulation
> 收件人:
> 日期: 2009 3 23 星期一 上午 4:41
> --- *2009年3月23日 星期一,naresh
/<alexdowson@hotmail...com>/*
> 寫道﹕
> 寄件人: naresh
of a
> 收件人:
> 日期: 2009 3 23 星期一 上午 4:33
> Hi
> in Which line you are getting
> of code ?
> Hmmm... You can try this instead of this
> vector<Delaunay_triangulation::Facet> f; with
> list<Delaunay_triangulation::Facet> f;
> try list instead of vector.
> *From:* Query Cgal
> *To:*
> *Sent:* Monday, March 23, 2009 9:47 AM
function
> Hi.
> Finally, I have tried with the following code
to use the
> incident_facets function.
> Delaunay_triangulation Dt;
> Dt.insert(Point(0,0,0));
> Dt.insert(Point(10,0,0));
> Dt.insert(Point(5,10,0));
> Dt.insert(Point(8,8,0));
> Dt...insert(Point(-3, -20, 0));
> Dt.insert(Point(-5,10,0));
> Finite_vertices_iterator start =
> Dt.finite_vertices_begin();
> However, when it has
"System.NullReferenceException'
> May I ask is it due to the nature of the
points that I
> have inserted into the triangulation?
> I am using CGAL-3.3.1 and Visual C++ 2005
> And I am using the triangulation with the
following
> declaration.
> Thank you very much for your help.
> typedef CGAL::Cartesian<double> Rep_class;
> typedef CGAL::Vector_3<Rep_class> Vector;
> typedef CGAL::Point_3<Rep_class> Point_3;
> typedef CGAL::Object CGAL_object;
> template < class GT, class Vb =
> CGAL::Triangulation_vertex_base_3<GT> >
> class Vertex_base_for_ssr
> : public Vb
> public:
> typedef typename Vb::Vertex_handle Vertex_handle;
> typedef typename Vb::Cell_handle Cell_handle;
> typedef typename Vb::Point Point;
> template < class TDS2 >
> struct Rebind_TDS {
> typedef typename Vb::template
> Rebind_TDS<TDS2>::Other Vb2;
> typedef Vertex_base_for_ssr<GT,
> Vb2> Other;
> Vector surface_normal;
> vector<Vertex_base_for_ssr<GT, Vb> *>
> neighbor_vertex_handle;
> double fifth_nearest_dist;
> int surface_label;
> bool is_safe;
> Vertex_base_for_ssr() : Vb()
> surface_label = -1;
> is_safe = false;
> Vertex_base_for_ssr(const Point& p)
> : Vb(p)
> coordinate[0] = p.x();
> coordinate[1] = p.y();
> coordinate[2] = p.z();
> surface_label = -1;
> is_safe = false;
> Vertex_base_for_ssr(const Point& p,
Cell_handle c)
> : Vb(p, c)
> surface_label = -1;
> is_safe = false;
> void set_surface_normal(double x_i, double
y_i, double
> z_i)
> surface_normal = Vector(x_i, y_i, z_i);
> Vector get_surface_normal()
> return surface_normal;
> Point get_point()
> return Vb::point();
> double coordinate[3];
> void set_coordiante()
> coordinate[0] = point().x();
> coordinate[1] = point().y();
> coordinate[2] = point().z();
> typedef
> CGAL::Exact_predicates_inexact_constructions_kernel K;
> typedef
> CGAL::Triangulation_data_structure_3<Vertex_base_for_ssr<K>
> > Tds;
> typedef CGAL::Delaunay_triangulation_3<K, Tds>
> Delaunay_triangulation;
> --- 2009年3月21日 星期六,naresh
寫道﹕
> 寄件人: naresh
function of
> 收件人:
> 日期: 2009 3 21 星期六 下午 1:47
> Hi
> >>In fact, I am
dealing with a 3D triangulation
> (sorry that I forgot to mention that it is 3D
in the
> >>previous post.)
> >>and therefore, I cannot use Facet since
Facet is
> not represented in 3D triangulation.
> >>So, what should I do to use
incident_facets() of a
> 3D triangulation.
> I donot know which
triangulation are you using. for
> simple triangulation here there you can
define Facet
> easily .. here is code..
> try to modifiy with ur code
> typedef
> typedef CGAL::Triangulation_3<K>
Triangulation;
> typedef Triangulation::Facet Facet;
> If there is still confusion post some
code . But i
> will not able reply today because saturday
now and i am
> off. :) I can reply on monday.
> > Hope this helps
> Alex
> From: Query Cgal
> To:
..fr
> Sent: Saturday, March 21, 2009 6:46 PM
incident_facets
> THank you for your reply.
> In fact, I am dealing with a 3D
triangulation
in the
> previous post.)
since Facet is
> a 3D triangulation.
> Thank you
寫道﹕
> 寄件人: naresh
incident_facets
> 收件人:
> 日期: 2009 3 21 星期六 下午 1:07
> Hi
> I
think you should try like this
> typedef Trianluation_2::Facet Facet; //
> something here that you had used in ur
programme may
> different i had showed only example
> vector<Facet> f;
back_inserter(f));
> From: Query Cgal
> To:
2009 5:45 PM
> Subject: [cgal-discuss]
incident_facets
> Hi, I have tried to use the
function below
> template <class OutputIterator>
> OutputIterator t.incident_facets (
> Vertex_handle v, OutputIterator facets)
> Copies all Facets incident to v to
> the output iterator facets. Returns the
resulting output
> iterator.
> Precondition: t..dimension() >1 , v
> Vertex_handle(), t.is_vertex(v)..
> When I tried to used it in the following
> way but it didn't work,
> vector<Finite_facets_iterator> f;
back_inserter(f));
> May I ask in what other way
should I use
> the Output iterator then ?
> Thank you
> Yahoo!香港提供網上安全攻略,
教你如何防範
> 黑客!了解更多
> Yahoo!香港提供網上安全攻略,教你如何
防範黑客!了
> 解更多
> Yahoo!香港提供網上安全攻略,教你如何防範黑客!
*了解更多*
> <http://hk.promo.yahoo.com/security/
<http://hk.promo..yahoo.com/security/>>
> Yahoo!香港提供網上安全攻略,教你如何防範黑客!*了解更多*
<http://hk..promo.yahoo.com/security/>>
> <http://hk.promo.yahoo.com/security/>
-- You are currently subscribed to cgal-discuss.
Yahoo!香港提供網上安全攻略,教你如何防範黑客!*了解更多* <http://hk..promo.yahoo.com/security/>
