- To:
- Subject: Re: [cgal-discuss] Halfedge_around_vertex_circulator
- Date: Tue, 07 Apr 2009 22:42:42 +0200
Let me just confirm that it IS the case.
andreas
Benjamin schwarz wrote:
according to the documentation it seems to be the case :
"The polyhedral surface provides convenient circulators for the
counterclockwise circular sequence of halfedges around a facet and the
clockwise circular sequence of halfedges around a vertex."
( found on page
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Polyhedron/Chapter_main.html
section 21.3.6 ).
If you don't trust it, you can still implement it by successions of
next()->opposite() operations, I guess.
Ben
On Thu, Apr 2, 2009 at 9:07 PM, Priyamvad Deshmukh
wrote:
I need to calculate the angle defect at each vertex of a polyhedron.
Will the Hafedge_around_vertex_circulator always give me halfedges in a
sequence? For example can two consecutive edges returned from the circulator
be used to calculate the angle defect?
Priyamvad
- [cgal-discuss] Halfedge_around_vertex_circulator, Priyamvad Deshmukh, 04/02/2009
- Re: [cgal-discuss] Halfedge_around_vertex_circulator, Benjamin schwarz, 04/07/2009
- Re: [cgal-discuss] Halfedge_around_vertex_circulator, Andreas Fabri, 04/07/2009
