cgal-discuss - Re: [cgal-discuss] Alpha Shape Question
  • To:
  • Subject: Re: [cgal-discuss] Alpha Shape Question
  • Date: Wed, 8 Apr 2009 01:42:45 -0600
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type:content-transfer-encoding; b=MUT3xCnZXpUei4gW4a0VcBKA0+T0fCfObWVE/SBSoIlp3gKsFAngHg+TJjuR5QhWaC ET5OH8zf2+sNOO+mYr6/v1dJOobUsYYM87IPa6GgskOe4RJKrs0dWtVlgQinG97LI4KU 0HB2kAHe+6mvJwSmaTbsDfJXbzBVp3qxGN3lk=
Thank you very much Ben !
Omar
On Wed, Apr 8, 2009 at 1:23 AM, Benjamin schwarz
wrote:
> Hello Omar and Naresh,
>  I wrote a few C++ lines some times ago to convert the border of an
> Alpha_shape_3 to an HDS. I cleaned my code and tried to make it more
> generic, you can download it on this webpage :
> http://alnitak.u-strasbg.fr/~schwarz/benjamin-schwarz-igbmc-Code-CGAL-AlphaPolyhedron.html#benjamin-schwarz-CGAL-Polyhedronification-Downloads
>  The HDS allowed me to cheat and build a "combinatorially manifold"
> object representing the border of the alpha shape for any alpha value
> (even in Alpha_shape_3::GENERAL mode), which seems to be impossible
> with the Polyhedron_3 class though it is built on a HDS.
>  The Polyhedron_3 class seems to redefine its iner items (such as
> Halfedges) and disallow some of their functionalities (for instance
> Halfedge::set_next() is made private). The only way to modify a
> Polyhedron inner HDS is thus to use a Polyhedron_builder_3, which
> seems to prohibit the existence of "degenerate" cases such as two
> facets with the same three corner vertices, edges sharing the same
> pair of vertices, or connections of volume (or voids) through one
> vertex (which occur oftenly on the alpha shape border).
>             --Ben
> On Fri, Apr 3, 2009 at 8:42 AM, naresh
> wrote:
>> Hi Omar
>> Thanx for help... Your code helps me
>> Naresh
>> ----- Original Message ----- From: "omar rodriguez"
>> To:
>> Sent: Thursday, April 02, 2009 11:50 AM
>> Hello naresh
>> you might find this of use
>> https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2009-03/msg00087.html
>> Cheers
>> Omar
>> On Wed, Apr 1, 2009 at 11:55 PM, naresh
>> wrote:
>>> Hi
>>> Can i convert Alpha shape 3 to Polyhydron ?
>>> I looked at code for increment build of Polyhydron is this right method to
>>> build polyhydron from Alpha shape ?
>>> Basically I am building 3D mesh from points and I want simplify Alpha
>>> Shape
>>> with edge_collapse method so i need input as Polyhydron.
>>> Any good method ?
>>> naresh
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
