- To: <>
- Subject: Re: [cgal-discuss] Alpha Shape Question
- Date: Fri, 3 Apr 2009 12:12:51 +0530
Hi Omar
Thanx for help... Your code helps me
Naresh
----- Original Message ----- From: "omar rodriguez" <>
To:
Sent: Thursday, April 02, 2009 11:50 AM
Hello naresh
you might find this of use
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2009-03/msg00087.html
Cheers
Omar
On Wed, Apr 1, 2009 at 11:55 PM, naresh
wrote:
Hi--
Can i convert Alpha shape 3 to Polyhydron ?
I looked at code for increment build of Polyhydron is this right method to
build polyhydron from Alpha shape ?
Basically I am building 3D mesh from points and I want simplify Alpha Shape
with edge_collapse method so i need input as Polyhydron.
Any good method ?
naresh
- Re: [cgal-discuss] c2t3 question - finding the Delaunay traingulation, naresh, 04/01/2009
- [cgal-discuss] Alpha Shape Question, naresh, 04/02/2009
- Re: [cgal-discuss] Alpha Shape Question, omar rodriguez, 04/02/2009
- Re: [cgal-discuss] Alpha Shape Question, naresh, 04/03/2009
- Re: [cgal-discuss] Alpha Shape Question, Benjamin schwarz, 04/08/2009
- Re: [cgal-discuss] Alpha Shape Question, omar rodriguez, 04/08/2009
- Re: [cgal-discuss] Alpha Shape Question, naresh, 04/08/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] c2t3 question - finding the Delaunay traingulation, Mariette Yvinec, 04/01/2009
- Re: [cgal-discuss] c2t3 question - finding the Delaunay traingulation, Sean McDuffee, 04/01/2009
