cgal-discuss - Re: [cgal-discuss] Alpha Shape Question
  • To: <>
  • Subject: Re: [cgal-discuss] Alpha Shape Question
  • Date: Wed, 8 Apr 2009 15:48:18 +0530
Dear Ben
Thanx for sharing code... :)
Regards
Naresh Radadiya
Winner Technologies®
M-7 to 13 Ashirwad Complex,
Near Yash Plaza
Varacha Road,
Surat - 395006
Gujarat
India
Ph: +91-261-2554572
Mob: 9913089299
web : www.winner.co.in
mail :
----- Original Message ----- From: "Benjamin schwarz" <>
To:
Sent: Wednesday, April 08, 2009 12:53 PM
Hello Omar and Naresh,
I wrote a few C++ lines some times ago to convert the border of an
Alpha_shape_3 to an HDS. I cleaned my code and tried to make it more
generic, you can download it on this webpage :
http://alnitak.u-strasbg.fr/~schwarz/benjamin-schwarz-igbmc-Code-CGAL-AlphaPolyhedron.html#benjamin-schwarz-CGAL-Polyhedronification-Downloads
The HDS allowed me to cheat and build a "combinatorially manifold"
object representing the border of the alpha shape for any alpha value
(even in Alpha_shape_3::GENERAL mode), which seems to be impossible
with the Polyhedron_3 class though it is built on a HDS.
The Polyhedron_3 class seems to redefine its iner items (such as
Halfedges) and disallow some of their functionalities (for instance
Halfedge::set_next() is made private). The only way to modify a
Polyhedron inner HDS is thus to use a Polyhedron_builder_3, which
seems to prohibit the existence of "degenerate" cases such as two
facets with the same three corner vertices, edges sharing the same
pair of vertices, or connections of volume (or voids) through one
vertex (which occur oftenly on the alpha shape border).
--Ben
On Fri, Apr 3, 2009 at 8:42 AM, naresh
wrote:
Hi Omar
Thanx for help... Your code helps me
Naresh
----- Original Message ----- From: "omar rodriguez"
To:
Sent: Thursday, April 02, 2009 11:50 AM
Hello naresh
you might find this of use
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2009-03/msg00087.html
Cheers
Omar
On Wed, Apr 1, 2009 at 11:55 PM, naresh
wrote:
Hi
Can i convert Alpha shape 3 to Polyhydron ?
I looked at code for increment build of Polyhydron is this right method to
build polyhydron from Alpha shape ?
Basically I am building 3D mesh from points and I want simplify Alpha
Shape
with edge_collapse method so i need input as Polyhydron.
Any good method ?
naresh
