- To: <>
- Subject: RE: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion
- Date: Mon, 4 May 2009 18:08:00 +0800
2 more questions:
1- I've been playing with the demo for a while, but limited to be a off
model
visualizer. I just tested the polyhedron simplification functionality with
a couple of off models. To my surprise, with almost all of them, I get a
result
that I think definitely buggy - they are obvious a reasonable simplification
of the original ones. I'm wondering if I've missed something abvious - I
just gave a relatively smaller figure than given as default for the number
of edges
in the dialog box. And meanwhile, what I desire is that I could have chance
to control the approximation more intuitively. For example, I hope I could
give the maximum deviation of the resultant vertices from the plane of the
original facets.
2- Is the source code of the polyhedron_3 demo available?
Thanks for any further help.
B/Rgdss
Max
> Hi Max,
> The package Triangulated Surface Mesh Simplification in
> the Geometry Processing Part of the manual
> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/packages.html#part_
> XI
> is exactly about that.
> andreas
- [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion, Max, 05/03/2009
- Re: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion, Andreas Fabri, 05/03/2009
- RE: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion, Max, 05/04/2009
- Re: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion, Andreas Fabri, 05/04/2009
