cgal-discuss - RE: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion
  • To: <>
  • Subject: RE: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion
  • Date: Mon, 4 May 2009 09:12:57 +0800
Hello Andreas,
Thank you for the direction.
B/Rgds
Max
> -----Original Message-----
> From: Andreas Fabri
> [mailto:]
> Sent: Monday, May 04, 2009 4:52 AM
> To:
> Subject: Re: [cgal-discuss] (Nef_)Polyhedron simplification with a given
criterion
> Hi Max,
> The package Triangulated Surface Mesh Simplification in
> the Geometry Processing Part of the manual
> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/packages.html#part_
> XI
> is exactly about that.
> andreas
> Max wrote:
> > Hello CGAL guys,
> > I want to know if there is a tool out of there that can simplify
> > a polyhedron_3, or nef_polyhydron_3, according to a given
> > criterion of approximation.
> > By the word 'simplify', I mean to decrease, as much as possible,
> > the size of the object, in number of vertices, facets, etc.
> > For example, I want to merge the small facets that are nearly
> > coplanar, according to the criterion, into a larger one.
> > I want to decrease the size/complexity of the 3d obj's with the hope
> > of promote the calculation efficiency without much loss of precision.
> > Thanks for any hints.
> > B/Rgds
> > Max
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
