- To:
- Subject: Re: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion
- Date: Sun, 03 May 2009 22:51:56 +0200
Hi Max,
The package Triangulated Surface Mesh Simplification in
the Geometry Processing Part of the manual
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/packages.html#part_XI
is exactly about that.
andreas
Max wrote:
Hello CGAL guys,
I want to know if there is a tool out of there that can simplify
a polyhedron_3, or nef_polyhydron_3, according to a given
criterion of approximation.
By the word 'simplify', I mean to decrease, as much as possible,
the size of the object, in number of vertices, facets, etc.
For example, I want to merge the small facets that are nearly coplanar, according to the criterion, into a larger one.
I want to decrease the size/complexity of the 3d obj's with the hope
of promote the calculation efficiency without much loss of precision.
Thanks for any hints.
B/Rgds
Max
- [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion, Max, 05/03/2009
- Re: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion, Andreas Fabri, 05/03/2009
- RE: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion, Max, 05/04/2009
- Re: [cgal-discuss] (Nef_)Polyhedron simplification with a given criterion, Andreas Fabri, 05/04/2009
